View Full Version : quick and easy flooded stuffing tube
kfxguy
12-19-2014, 12:42 AM
I havent built a mono just yet but I had some ideas on how I would do the drive tube and have it adjustable. I've seen people do a flooded tube with a boot on the interior end, good idea but I wanted to be different. So I used an idea from my cat builds. I like the idea of being able to remove the drive tube if I need to so I make a slip joint. I did the same on this little mono. This thing came with a strut.....but it was just for looks. I could not believe it when I figured out it was non adjustable from the factory...who does that? Lmao! Anyway I made a short one as it does need much adjustment. Here's what I did:
Ripped out the stock drive tube. Drilled a hole bigger for my brass flooded tube. Removed the epoxy from old tube.
http://i218.photobucket.com/albums/cc243/ltzguy/20141218_201436.jpg (http://s218.photobucket.com/user/ltzguy/media/20141218_201436.jpg.html)
Then I cut my brass tube. 27/64 is what I used. Then I found a nut to fit snug in the tube. Drilled it to fit the slip tube.
http://i218.photobucket.com/albums/cc243/ltzguy/20141218_201504.jpg (http://s218.photobucket.com/user/ltzguy/media/20141218_201504.jpg.html)
Assembled it.
http://i218.photobucket.com/albums/cc243/ltzguy/20141218_203226.jpg (http://s218.photobucket.com/user/ltzguy/media/20141218_203226.jpg.html)
kfxguy
12-19-2014, 12:45 AM
Then I filled with jb weld to hold it together. Recess the nut some, slide tube in a little and put jb weld around it.
http://i218.photobucket.com/albums/cc243/ltzguy/20141218_203723.jpg (http://s218.photobucket.com/user/ltzguy/media/20141218_203723.jpg.html)
Slide it in and check fitment.
http://i218.photobucket.com/albums/cc243/ltzguy/20141218_213812.jpg (http://s218.photobucket.com/user/ltzguy/media/20141218_213812.jpg.html)
http://i218.photobucket.com/albums/cc243/ltzguy/20141218_213847.jpg (http://s218.photobucket.com/user/ltzguy/media/20141218_213847.jpg.html)
kfxguy
12-19-2014, 12:50 AM
I'm sure you can see why I needed to so this and upgrade to 3/16 flex at the same time. That motor you see is a good bit more power than stock.
http://i218.photobucket.com/albums/cc243/ltzguy/20141218_224504_1.jpg (http://s218.photobucket.com/user/ltzguy/media/20141218_224504_1.jpg.html)
And finished. I point the front of the boat and poured epoxy in to hold the flooded tube in place. Thought this may be helpful in giving some ideas. In a custom built boat I would make the flooded tube a little longer but this serves it's purpose. The stuffing tube slides through it btw, put a little silicon to seal it.
http://i218.photobucket.com/albums/cc243/ltzguy/20141218_224524_1.jpg (http://s218.photobucket.com/user/ltzguy/media/20141218_224524_1.jpg.html)
TheShaughnessy
12-19-2014, 09:56 AM
Nice little how to. Glad you did this, read you describing it on the thread where the boot was used. I was just gonna fill the end with resin/filler and drill out a hole then put the slip tube. I like the nut to keep it centered.
kfxguy
12-19-2014, 10:40 AM
Thanks! I actually angled the tupe up slightly to help with the angle of the flex tube. I mainly did this because ive had people pm me on how to do it. Why, I have no idea because ive never done one until now. I've told them how i would do it, but now i had a reason to need to in this boat. it had a really bad negative angle on the prop that i wanted to level out. Well when i tried to angle it, the drive tube broke. so hence the reason for this thread. i'm sure theres a better way, just wanted to throw some ideas out there. I'm fine with anyone posting in here how they did thiers.
TheShaughnessy
12-19-2014, 11:25 AM
Are you really gonna run that motor In there?
Luck as a Constant
12-19-2014, 11:51 AM
Looks good. But with a flood chamber that short, how much adjustment do you actually get?
I'm not sure how long it actually is, or if the nut acts as a pivot point in some way?
I totally understand this is just a test of the idea, and given the opportunity you would make it longer....
kfxguy
12-19-2014, 11:54 AM
yes, why?
kfxguy
12-19-2014, 11:58 AM
I dont need much adjustment at all. i'm just playing around with this boat. the tube actually slide so i can add negative or postive prop angle and about 3/16" up and down stru adjustment. better than nothing for sure. If this thing does as well as i hope, i may rip the interior out and redo it travis style. lol
Luck as a Constant
12-19-2014, 11:59 AM
Haha no doubt man.
Luck as a Constant
12-19-2014, 12:01 PM
I have a habit of completely rebuilding factory crap. This was a factory white ibanez. Can't have that tho lol
http://tapatalk.imageshack.com/v2/14/12/19/d953780d2571defd852e62969791153e.jpg
runzwithsizorz
12-19-2014, 12:07 PM
I too, liked the idea of being able to remove the drive tube if I need to, maybe going from no liner, to lined. On a mono however, I still wanted to use a stinger. Using button head screws, and J B wield I
secured a piece of sheet metal to the stinger. Even though the motor is mounted far forward, I still needed to angle the tube up. I did this by shaping a small block of wood, and glued it to the hull. The
tube was secured to the block with a plastic pipe hanger, 2 small screws, and A LOT of glue, not pretty, but it ain't going anywhere, a radio box goes over it. Used the largest rubber boot Steven sells, and a couple of clamps.
The T bar oiler adjusts up down, left, and right, and locks the stuffing tube in place.
125580125581
TheShaughnessy
12-19-2014, 12:12 PM
I thought about keeping the stinger on my mono build but I was like, not enough meat on this stinger, now I see how you did it.
kfxguy
12-19-2014, 12:20 PM
What's wrong with My motor choice? Lol
runzwithsizorz
12-19-2014, 12:35 PM
In my high school auto shop class, we put a 427 in the back seat of a Corvair, so I would say, not a darn thing.:thumbup1:
kfxguy
12-19-2014, 12:48 PM
Well this boat can only hold a 3s pack without getting badly unbalanced. So I plan on running on 3s only. I have this same setup in my son's 26" hydro. It's not unruly. 40mm 1.4 pitch prop and it does 30 mph.
TheShaughnessy
12-19-2014, 05:09 PM
It just looked big in there , I was thinking higher cell count. Maybe whip up a cf rear support?
kfxguy
12-19-2014, 05:22 PM
I had planned on it. I have to wait till the water jacket makes it here.
tlandauer
12-19-2014, 07:49 PM
:rockon2::rockon2: it's the only way.:banana::banana:
tlandauer
12-19-2014, 07:50 PM
Travis, that is a great set up, can be applied to many other RTR boats, thanks for sharing!
kfxguy
12-19-2014, 08:20 PM
Thanks! I'll be building my first mono fairly soon and will apply something like this to it except using carbon tubes.
flraptor07
12-21-2014, 08:47 PM
That's what I'm talkin' about, it's easier to slow it down than make it go faster!! :laugh::thumbup:
