View Full Version : Swordfish 240 esc 2 pack lipo setup
DeltaForceMan
12-11-2014, 06:25 PM
If I'm running two lipo packs too a swordfish 240 esc will I be ok soldering a Y setup on the esc.. (like a stock traxxas erevo esc comes set up).
tlandauer
12-11-2014, 06:43 PM
Why do you need a "Y"? if you are connecting the batteries in series, just hook up the batteries' + to- and the other + and - goes to the ESC.125309
if it is parallel then you need a parallel adapter . 125310
I am assuming you are using bullet connecters.
kfxguy
12-12-2014, 12:50 AM
***edit*** this only applies is your doing them in series. You never stated one way or the other.
Here's how I did mine...
http://i218.photobucket.com/albums/cc243/ltzguy/20141207_133651.jpg (http://s218.photobucket.com/user/ltzguy/media/20141207_133651.jpg.html)
This a seaking 180. I did the wires the same. Run the red one way, black the other and then a jumper between the positive left on one battery to the negative on the other battery. Essentially makes a loop through them. You can see it better on the swordfish 240. That black wire going under it is just a jumper. Hope this helps.
http://i218.photobucket.com/albums/cc243/ltzguy/20141119_220701.jpg (http://s218.photobucket.com/user/ltzguy/media/20141119_220701.jpg.html)
DeltaForceMan
12-12-2014, 05:57 AM
Awesome, thanks guys!
You still didn't mention in Series or Parallel ? Very important :thumbup1:
tlandauer
12-12-2014, 10:27 AM
And what type of connectors?
DeltaForceMan
12-12-2014, 10:47 AM
It would be two packs in series with 6.5 castle bullet connectors
tlandauer
12-12-2014, 11:53 AM
Thanks for letting us know.
:beerchug:
