IMPBA D4 P-Limited Guidelines for 2015
  • DPeterson
    • 842
    It's official. 2015 P-limited Guidelines.
    Two basic points; Seperating rtr from purpose built boats and added the TP 3630 1950 to our approved motor list.
    IMPBA DISTRICT FOUR
    ELECTRIC CLASSES GUIDELINES
    P-LIMITED STOCK
    P-Limited Stock is a Ready to Run class for beginners or other racers wishing to get water time while providing the beginners some racing action. These are box stock boats. Modifications allowed, are the use of another transmitter/receiver, an aftermarket prop and any repairs to the boat due to damage or manufacture defect. Battery must be 4S or below. Approved, suggested boats and classes;
    MONO – Aquacraft Supervee, Aquacraft Revolt, Proboat Impulse, Traxxas Spartan
    SPORT HYDRO – Aquacraft UL1, Proboat Elam
    CATAMARAN – Aquacraft Motley Crue, Aquacraft Lucas Oil, Proboat Miss Geico
    P-LIMITED SUPER STOCK
    P-Limited Super Stock is a step up from the Stock class. These are generally purpose built boats utilizing the basic motor specifications that come in the Ready to Run boats. The motor can dimensions must not exceed 36mm diameter by 65mm long. The manufacturers KV rating must not exceed 2030. Batteries in this class must be 4S or below. Any electronic speed control is acceptable. Hull must not exceed 34” in length. All motors in the class must be approved by the IMPBA D4 Tech Committee. Current approved motors are the AQ 1800, AQ 2030, Proboat 1800, and the TP 3630 1950. Classes and suggested boats;
    MONO – HOR/TFL Pursuit, Delta Force Cyberstorm, Aeromarine Challenger
    SPORT HYDRO – Blazer Whiplash, Thomas Stealth, M&L Sport 20, Insane 30
    OPC TUNNEL – Woodstuff 28 or 30, M&L PS295 or PS300, AQ Topspeed 3 or Villian
    MISCELLANEOUS INFORMATION
    In the case of not having enough Stock-rtr boats to make a 3 boat minimum, the Mono’s, Sport Hydro’s and Catamarans may be put in the same heats. Attempts will be made to run all the Stock-rtr together. There may be cases where we run Stock-rtr boats with Super Stock Boats to make the 3 boat requirement. Stock-rtr boats are welcome to run with the Super Stocks – just not recommended.
    Not all Clubs in District 4 will be offering all 6 of these classes. Check with the Race Club you plan to race with, on which classes are offered.
    IMPBA DISTRICT FOUR FE DIRECTOR – Doug Peterson, 608-393-7960, [email protected]
    Doug Peterson
    IMPBA 19993
    www.badgerboaters.com
  • jakal
    • Jun 2011
    • 21
    Doug, that is good news for District 4.
    Can you tell me if the Insane FE 30 is legal in the P-Limited Super stock class?
    thanks
    jacko'
    • DPeterson
      • 842
      Yes Jacko it is. I guess I could have and should have also listed the Insane 30 on our suggested hull list. Just do not see them in our area. I'll edit the list.
      Doug
      Doug Peterson
      IMPBA 19993
      • jakal
        • Jun 2011
        • 21
        thank you
        jacko'
        • properchopper
          • 6968
          Proud of you, Sir
          • TheShaughnessy
            • 1431
            A spartan measures 36" not sure if you have a length limit for stock.
            • DPeterson
              • 842
              No length limits for Stock. Just two requirements - Box stock and 4S or less.
              Our "Guidelines" are developed for increasing participation, racer development and racing fun. No one we associate with gives a hoot about records or national bragging rites therefore making the NAMBA P-Limited rules ineffective for us.
              Doug Peterson
              IMPBA 19993
              • TheShaughnessy
                • 1431
                Should work. a super vee vs a spartan, that would be a sight to see, could be either boats race to win depending on conditions.
                • RandyatBBY
                  • Sep 2007
                  • 3915
                  Great work Doug! I like it.
                  Randy
                  BBY Racing
                  • DPeterson
                    • 842
                    Got a nitro that guy that just bought a Spartan. IMO Traxxas got the length correct. The 3S versus a 4S will be interesting. I don't currently own a box Stock. Looking at the Spartan myself.
                    Doug Peterson
                    IMPBA 19993
                    • Darin Jordan
                      • 8335
                      Nice, Doug.
                      Is there a reason you've left off the new Dynamite/Pro Boat 2000KV 6-Pole (BJ29 V3 motor)??
                      Darin E. Jordan - Renton, WA
                      • DPeterson
                        • 842
                        Darin
                        Any motor added to our list will have to go through a day of testing/data logging by our D4 Tech Committee in order to be included. We are going to keep our motors matched up by on water testing and not by manufactures listed specifications. If the need arrises we are not opposed to reviewing the Proboat.
                        Doug
                        Doug Peterson
                        IMPBA 19993
                        • Doug Smock
                          Moderator
                          • 5272
                          Good stuff Doug.
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • DPeterson
                            • 842
                            Thanks for the words of support. The written "Guidelines" was the easy part. We now have to put the rubber on the pavement and create some traction. We'll first try to get some of the past rtr guy's to come back. Their first experience racing their rtr's against us was not all that pleasant.
                            I guess I will pass on the Traxxas. 1400 KV. What the H does one do with that?
                            Doug
                            Doug Peterson
                            IMPBA 19993
                            • Darin Jordan
                              • 8335
                              Doug
                              I know at the 2012 Nationals with 1500KV, I didn't do anything with it other than run away in P-Ltd Cat and P-Ltd Offshore, turning a X450/3 prop... Right up until it would either blow off or torque-roll around lap 3...
