View Full Version : finding the center of the transom
dasboata
11-16-2014, 11:52 AM
I picked this up from mounting full size outboards ! pretty handy !!! Mine is very crud and quick job but I imagine you can do alot better version
Rocstar
11-16-2014, 12:24 PM
:thumbup1:
properchopper
11-16-2014, 12:39 PM
:thumbup1::thumbup1:
Chilli
11-16-2014, 04:49 PM
We can make a prettier version but it ain't going to be any more accurate. Cool Trick. Thanks for sharing.
ray schrauwen
11-16-2014, 04:55 PM
Excellent!! Reminding me of my grade 9 machine shop technique to find the center of the end of round stock. Kudos for applying it to something I can use now!!
kfxguy
11-16-2014, 05:17 PM
Nice trick!
Fella1340
11-16-2014, 05:49 PM
I like!
flraptor07
11-16-2014, 06:57 PM
Very cool trick, I'm gonna have to remember that one!:thumbup:
Kaotic
11-16-2014, 10:27 PM
I wished I would of saw this earlier this week!
tlandauer
11-16-2014, 10:54 PM
:rockon2::thumbup1::rockon2::thumbup1:
gsbuickman
11-17-2014, 12:15 AM
Hey Shawn, post up some pics of the dowel balancer you built , simple & kool :biggrin:
mml4
11-19-2014, 04:42 AM
How do you set the distance from the center of the dowel to the center of the pencil?
Thanks,
Marc
tlandauer
11-19-2014, 04:11 PM
Thanks,
Marc
Correct me if I am wrong: it doesn't matter, the distance between the dowel and the pencil is determined by the width of the transom, in this case the dowel is anchored at the strake and the distance is adjusted accordingly ( a practical distance so the two arcs can intersect on the tiny territory of the transom ) , what's important is the symmetrical character of the hull, if the strakes are not symmetrical ( highly unlikely) , then the intersecting point would not be in the middle. Unless i am missing something...
kevinpratt823
11-19-2014, 06:02 PM
Great idea! Could probably achieve a similar result just by locking a set of calipers at the given dimension and lightly scratching the gelcoat.
olwarbirds
11-19-2014, 06:57 PM
You can also use a drafting compass like we used in school to make circles..works just like the ops simple idea.
dasboata
11-19-2014, 08:07 PM
Correct me if I am wrong: it doesn't matter, the distance between the dowel and the pencil is determined by the width of the transom, in this case the dowel is anchored at the strake and the distance is adjusted accordingly ( a practical distance so the two arcs can intersect on the tiny territory of the transom ) , what's important is the symmetrical character of the hull, if the strakes are not symmetrical ( highly unlikely) , then the intersecting point would not be in the middle. Unless i am missing something...The distance does matter as you can see I had to drill another hole for this transom center. sounds like you got the Idea !
dasboata
11-19-2014, 08:19 PM
Thanks,
Marc
You can eyeball it to put you just over center with the pencil
tlandauer
11-19-2014, 08:36 PM
Poor choice of words on my part, eyeballing is exactly what I had in mind. Thanks!
