View Full Version : Cutting Flex Shaft
Revolt30
11-06-2014, 02:40 PM
Got a upgraded flex shaft for the Impulse 31 its to long! Can you cut the flex shaft and do you have to do anything to it when its cut?
Luck as a Constant
11-06-2014, 04:24 PM
I usually solder it then cut with a dremel
Make-a-Wake
11-06-2014, 05:18 PM
I use this cutting attatchment on mine
http://www.zoro.com/i/G3086702/?utm_source=google_shopping&utm_medium=cpc&utm_campaign=Google_Shopping_Feed&gclid=CKThntyA58ECFehzMgod1WoA0g
Revolt30
11-06-2014, 05:51 PM
Thanks.
Revolt30
11-06-2014, 05:52 PM
Thanks.
petej
11-09-2014, 11:19 PM
Using a Dremel with a cut-off wheel, cut the flex cable a bit longer then required, use acid flux which comes in a small bottle with a dripper-tip from the local hardware store, a small butane torch and solder. Heat some solder into a small molten pool, heat the flex end and drip the flux on the cable as you rotate the end in a pool of molten solder, so it soaks up the solder, evenly. Clean and cut to length.
