View Full Version : swordfish 220 a pro with data logger
nitrous8e
11-04-2014, 03:11 PM
i have a swordfish 220 amp pro with data logger i am using the lcd program box i can't seem to be able to set the lvc to a higher rate than 2.9 i want to set it 3.0+
i must be missing something on the lcd box setttings or where to find more settings
jim82
11-04-2014, 08:00 PM
rather then relying on lvc because higher quality lipos are going to react different and you may run them below 20%, start timing your runs with your setup and you will know when its time to bring her in
nitrous8e
11-14-2014, 01:02 PM
still would like to know where in the prgram menu all of the lvc setting can't find them above 2.9
montymike
11-14-2014, 02:18 PM
Were is ur cell count set ? Set on auto from factory
Try setting to the amou
nt of cells ur goung to run then then set ur lvc
