MAXAMUS
08-30-2008, 03:09 PM
Hi guys
well to cut a long story short my ESC seems to have died ! after a capsize all dried out for nearly a week
symptoms - 2x fresh charged lipo's 7.4v connected
TX switched on then power on, no beeps from ESC or throttle but power to servo
tests Ive carried out
swapped out the Rx to a futaba fasst 2.4GHz powered up same as above servo working ,still no beeps from ESC or any throttle ,then i reprogrammed the ESC and get the conformation beep that it has been performed successfully but still no throttle and still the servo works
OK so servo is fine i have a aero ESC i could test it with but it would mean having to swap the male connectors and solder 3 female bullet connectors on to be honest i cant be bothered to go to all that effort tomorrow i will get out the volt meter and see if there is any power output from the ESC throttle cable to Rx and then failing that i have this in mind
ETTI @125a water cooled ESC
http://cgi.ebay.co.uk/ETTI-125A-Water-cooled-Brushless-ESC-6-20cells-BEC_W0QQitemZ110174211355QQihZ001QQcategoryZ34058Q QtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
have read some good reports on this input from anybody using one of these would be great and AS ALLWAYS I VALUE ALL INPUT
thanks MAXAMUS...........
BJ 26 VIDEO http://www.youtube.com/watch?v=dDa5ZrCn81E
