View Full Version : anyone heard of Vac-U-Pickle
okieman98
10-15-2014, 01:00 AM
ran across these wonder if anyone has any experience with them, good are bad to buy
thanks
kfxguy
10-15-2014, 01:38 AM
Of course we've all heard of it! It's a neat little boat. I'm building one for my son right now...and now I kinda want one for myself!
tlandauer
10-15-2014, 02:36 AM
thanks
https://www.youtube.com/watch?v=e3GVsLhwBGA
Doug Smock
10-15-2014, 09:27 AM
http://forums.offshoreelectrics.com/showthread.php?3686-Chris-Harris-All-Star-quot-Electric-quot-Hydro-Shoot-Out
tlandauer
10-15-2014, 04:35 PM
Doug, those hydros look so good in your shop, I am lucky to have bought this one that was built by you! Love it! With the Neu 1509 they were awesome! I may try that for the N-2 Sport Hydro class. (just for fun for myself as i don't race)
OP: this hydro is not that big but it is a fun and well running boat! I also forgot to say that the hydro you saw in my YouTube clip was built by Doug Smock, I bought it here some years later through a third party...
okieman98
10-15-2014, 06:36 PM
looked good running what kind of speed u can get out of them. i think i will order one . might need advice on running gear on this i have never put one together
thanks
okieman98
10-15-2014, 07:01 PM
i was looking at one of the links above wonder what kind of paint he used since they are not fiberglass
Doug Smock
10-15-2014, 07:24 PM
http://vac-u-boat.com/Painting%20Tips%20Menu.htm
Doug Smock
10-15-2014, 07:35 PM
thanks
This link will help you with the build although I no longer use Teflon liners.
http://vac-u-boat.com/PickleSmockBuildPage.htm
All of the hardware on this build came from Ray Fuller. The guys can fill you in on other options.
http://stores.ebay.com/Fullers-Fast-Electrics-Model-Boats/Fullers-Precision-Hardware-/_i.html?_fsub=647292010&_sid=81385710&_trksid=p4634.c0.m322
okieman98
10-15-2014, 09:18 PM
thank u so much
okieman98
10-17-2014, 08:16 PM
have one more question i have a shockwave 26 bl , dont like the boat to much to slow , i have been told the motor is pretty good in these boats will it fit in the vac-u-pickle and what other parts can i use off of it
thanks
tlandauer
10-17-2014, 10:40 PM
If you have the 1500kv Proboat motor, then it is an excellent motor, speed will be slower than the UL-1's 2030kv motor, the ESC should work as well. I have the latter motor and use a X642 prop as well as a Grim 40x52/3 prop, all work well.
The motor will fit! The only thing you might have to pay attention is the clearance of the underside of the water jacket. The motor mount that is meant for the Vac-U-Pickle is a low mount, water jacket on the thick side may not clear, you need to slide the jacket slightly toward the back of the end bell. At least that is my finding, could be wrong though.
Whatever you do, don't part with that motor, that motor can be run with 6s as well. They are discontinued and together with the 1800kv motor , they are well liked by boaters!
okieman98
10-17-2014, 11:05 PM
ok thanks i was going to up grade the esc to run on 4 s are 6s what ever i can get in it. speed is the key for me want it to run with my cats. not sure what battery will fit in there
okieman98
10-17-2014, 11:10 PM
i just looked it does have the 1500 kv motor, and a 3s 45 amp esc
also have the the motley crew on 4s to
kfxguy
10-17-2014, 11:15 PM
thanks
The motor is about it. The esc would work but it's a little big in size. ..
tlandauer
10-17-2014, 11:24 PM
My Bad, i thought it came with the FasTech 45amp ESC which was rated for 4s. And Travis is right, space is limited.
I use the AquaCraft ESC, it barely fits across because the current version of the ESC has a longer cap.
okieman98
10-17-2014, 11:50 PM
ok then the rx and tx should work then i guessing
tlandauer
10-17-2014, 11:55 PM
yes Sir, the MR200 rx is a great unit, while the tx doesn't have model memory, it is still a good radio. :thumbup1:
kfxguy
10-18-2014, 12:18 AM
I ordered a seaking 60 amp esc which is smaller in size for mine. It was like 44 bux.
okieman98
10-18-2014, 12:21 AM
ok thanks everyone, all this info helps alot. cant wait to order it and get started
tlandauer
10-18-2014, 12:24 AM
Travis, which version? V2 or V3?
revoltrunner
10-20-2014, 09:05 PM
Here's mine. it's lots of fun and fast
tlandauer
10-20-2014, 09:37 PM
LOl...
Now this completes the package... Properchopper had long ago posted something like this.
122244 + 122245 :lol::lol::lol:
kfxguy
10-20-2014, 09:51 PM
The V3. It's very nice looking (like it's big brother) and compact. Came in today....only 2s and 3s tho
tlandauer
10-20-2014, 10:46 PM
Good to know! :thumbup1:
okieman98
10-21-2014, 08:38 PM
y can only ron 3 s on that esc 60 amp?
tlandauer
10-21-2014, 09:03 PM
Yes.
http://www.offshoreelectrics.com/proddetail.php?prod=ker-seaking-60a-v3
okieman98
10-21-2014, 10:27 PM
ok got lost somewhere with the research i have been doing, lol, i was thinking i saw these run on 4 s. going to order after the 1st of the month so drifting around finding where to get parts and so on.
tlandauer
10-21-2014, 10:33 PM
You should get an ESC that is 4s compatible. I think the 90A would be a good choice.
Sent from my Droid using Tapatalk 2
Doug Smock
10-21-2014, 10:36 PM
You did. I still run one on 2x2s 5000 45c wired in series with a AQ 2030 and 60a control. It runs great with a M cut X442.
http://www.offshoreelectrics.com/proddetail.php?prod=dh-aqcom-2030
Doug Smock
tlandauer
10-22-2014, 04:59 AM
To the OP,
I apologize for the extra exchange of info that had you confused. I have always used the AquaCraft ESC (60A) since I acquired this as a used boat from another member. The boat came with an older 45A ESC ( Aqua Craft) and it was set up laterally on a wooden platform which is epoxied to the floor. I up graded to the 60A ESC with a longer capacitor.
In order for the water lines to have a proper clearance on both sides I placed the ESC in such a way that half of the capacitor is inside the wooden stringers, luckily there are pre-formed holes and it was not a problem.
I suppose I could have mounted the ESC longitudinally and so it sits on top of the batteries, like in one of the pictures I believe Mr.Doug Smock had shown. It also affords a greater ease of adjusting your COG---point of balance for the boat. I didn't do it simply because the boat was set up this way and the wooden platform was "in the way" and also meant for a lateral set up. More importantly I was satisfied with the COG and I set my batteries as far forward as the hatch will allow.
How you set up the ESC is really a personal preference and I do prefer to set it attached to the hull rather than having it on top of the batteries---I don't trust myself with the ESC having to move it out of the way every time I need to change batteries.:wink:
My comment that "it is tight" had triggered the "extra" discussion on other possible alternate ESCs. :focus:
122309 122310
Brushless55
10-22-2014, 04:32 PM
Thank you for posting this Doug
I want to try this on my Red FE30 and give it some sparkle that was listed in that tips page :thumbup1:
okieman98
10-22-2014, 04:36 PM
since this is my first build any discussion on it is very helpful. and all opinions count on what works for everyone. i was just confused on size of esc because i have all 2 s 5000 40c lipos . and wanted to make very sure on what size will run a 4 s set up. since i don't race. i enjoys speed. so me and my son can race. this is the only source of info for me since there are no local clubs are shops with in 100 miles are so. thanks for the photos of your set up those help a lot when starting putting thing together. i do inspire to race in the future this one is just for play :thumbup1:
okieman98
10-22-2014, 04:43 PM
off topic some but if anyone has race trailers set up post some inside shots, had a cargo trailer give to me been working on it as well
Doug Smock
10-22-2014, 08:02 PM
The way you have your boat set up is the way I prefer and recommend as well. I like everything in it's own space. The less you have to move things around the better.
In the IROC series pickles I built, I didn't have a choice as the Hydra 120s wouldn't fit in front of the motors.
boredom.is.me
10-23-2014, 02:17 PM
Here is mine.
http://forums.offshoreelectrics.com/showthread.php?41831-Vac-U-Pickle
3660 2200kv
TGY Marine 120A
Nanotech 2S 4400mAh 65-130C x2 in series
CNC 42mm 1.4p prop in the video below
https://www.youtube.com/watch?v=HO-B2g1H8x4
okieman98
10-25-2014, 01:15 AM
it looks fast and fun.
tlandauer
10-25-2014, 02:05 AM
That is very reassuring, my heart skipped a beat when I saw your IROC series Pickles. :laugh:
