View Full Version : Larger dia. or more pitch
Daveknitter
10-07-2014, 03:38 PM
Considering making prop change not sure what to go after first larger dia. or more pitch. current set-up 40"deep vee, Leopard 5692-730kv,
Hydra Ice 2 12-cell 50 volt max, running 2-5 cells in series, X455 prop, runs middle 50s mph, every thing comes in barely warm. Is it a coin toss or rather just a lot of trial and error to either go for larger dia. or more pitch keeping in mind watching boat temps, if i'm looking for more speed. Which one should i go after first?
kfxguy
10-07-2014, 03:46 PM
I would try more pitch first if they offer the same prop you have now with more pitch.
properchopper
10-08-2014, 03:07 PM
Large heavy monos won't benefit from increasing the pitch as in your situation. You need more diameter so step up a notch.
kevinpratt823
10-08-2014, 03:12 PM
Or try a 455-3 blade.
Sent from my SCH-I535 using Tapatalk 2
Rocstar
10-08-2014, 03:14 PM
Agreed. Try a larger wheel first.
properchopper
Good call - mo'better acceleration that way as well
Make-a-Wake
10-08-2014, 03:39 PM
I'd try a Prather s240. 53.8 diameter and they are 1.5 ptch.Total pitch is 3.3 and your x455 is 3.0. should pick up at least 5-8 mph
