View Full Version : Double 2s or Single 4s?
vertman
10-02-2014, 10:42 PM
The owners manual says there is a slight performance advantage of using a single 4s lipo pack over double 2s packs in the Revolt 30.
Have any of you noticed any advantage in the real world? (assuming mah, C rating etc are the same?)
Thanks.
Chilli
10-02-2014, 11:02 PM
If you are using quality packs, do a good soldering job on your connectors and your wires aren't too long I doubt you will notice any difference.
Make-a-Wake
10-02-2014, 11:14 PM
Correct, you wont be able to tell any noticable difference with good bullet soldering and minimum wire length. 2 x 2s is the easiest to fit and keeps the boat balanced well.
