aquacraft rescue 17
  • hilyfe
    • Aug 2013
    • 63
    aquacraft rescue 17
    Is it possible to use 12v 12ah
    Or 6v 12ah battery on this boat?
    Do I need to change anything on this boat to use gel cell battery?
  • iop65
    • Mar 2013
    • 367
    first : i don't have one
    but i build /owned enough scale boats to give some advice
    aquacraft specs : 2200mah 11.1 lipo recommended
    so i guess a 12v 12 ah pb will almost sink that boat ( only about 1 meter)
    and a 6 v 12ah will also drop it to deep in the water and won't give want the standard motors want , will be a boring drive with that
    why don't you try lipo's with some higher capacity?
    • hilyfe
      • Aug 2013
      • 63
      Im afraid to burn down my house hahahah
      I have heard so many mishaps with lipos
      Dont over charged it
      Dont over discharged
      • Make-a-Wake
        FE Rules!
        • 5557
        Am I understanding that this is to be a "rescue" boat for your faster boats? If so, I'd throw something like this in it. You shouldnt need that much mah for rescue purposes only. you can probably go out 5-6 times with this 5000 mah nimh. Also a decent nimh batt should charge up to 1.35 volts would would give you 10.8 volts on this 8 cell. If you need more mah just get two. Good price .
        • hilyfe
          • Aug 2013
          • 63
          Would I need to change anything if I use this type of battery on the boat?
          Maybe use two of this battery in parallel instead
          For a longer run time?
          • Make-a-Wake
            FE Rules!
            • 5557
            Yes, u can run them parallel for 10,000 mah, or just swap out the batts when first one is depleted.
            • hilyfe
              • Aug 2013
              • 63
              Great thanx
              Looks like im collecting rc boats here
