View Full Version : Bit the Bullet
DRMead
09-24-2014, 07:11 PM
All,Decided to get a Lucas Oil cat.Arrived today,and got started tidying up the servo wires,and updating the collet,cable,teflon,etc. Got the stuffing-tube/cable aligned nicely also. I had a pair of 2S packs charged,and hooked them up Got a single beep from the esc.Steering worked fine,but no throttle yet.......................................approx 45 seconds or so then 2 or 3 more beeps.Throttle worked then.Is there a set amount of time before the esc arms or....??? :help: I dis-connected power,and re-connected , the same thing extended time for the esc to arm. Normal or not ?? Thanks
tlandauer
09-24-2014, 07:34 PM
Yes! When you hear the first beep, pull full throttle ( trigger), then wait for another beep, release the trigger right away. 3 beeps will confirm and you are good to go. Do it every time, the Aqua Craft ESC forces you to do thid each time batteries are connected.
DRMead
09-25-2014, 07:00 AM
TL,I went through the manuel before the bench test,and didn't see any special instructions.Thanks a bunch for the heads up. appreciated.
