View Full Version : 1500 kv vs 1800kv
squirrly
07-15-2014, 06:12 PM
Hey is there really much of a difference in performance between the 1500 kv 1800kv
tlandauer
07-15-2014, 06:56 PM
Depending on how you will use them. Put them in a Proboat Impulse ( for instance) with 4s, the 1800 is faster. Run the 1500 with 6s and it will go faster than the 1800 which is not really a 6s motor, assuming that very similar if not the same prop is used on either set ups.
Both are excellent motors and by the way they are discontinued in their ¨second iteration¨as Dynamite motors.
squirrly
07-15-2014, 08:12 PM
Okay thanks for the info!!!! Why are they being discontinued and what are they going to offer??? I have the bj 29. My motor is shot. Bearing or something. Its very hard to turn. . And im really not to sure what kind of motor to replace the stock one with
JimClark
07-15-2014, 08:59 PM
The 1500 has more torque also
Sent from my SGH-T989 using Tapatalk
kfxguy
07-16-2014, 12:57 AM
I can fix the motor for you. ..
BHChieftain
08-20-2014, 09:34 AM
I personally like the 1500kv motor even on 4S using a larger prop on the proboat cats. For racing the extra torque helps get off the turns with faster acceleration, and also more pop for sports boating. Technically it is a bit slower in a straight line but the difference is not enough to be a real factor in racing given the race water conditions, driving lines, etc-- more torque and getting out of the turns with quicker acceleration can be an advantage.
Chief
skeeler
08-22-2014, 09:20 AM
Chief, what bigger prop do you run with the 1500 motor?
