View Full Version : Waterproof servos
mtgoat
08-18-2008, 08:05 AM
Traxxas makes a line of waterproof servos. Why have none of the other manufacturers thought of this before?:confused1: Steve, is there any possibility of carrying these?
Eyekandyboats
08-18-2008, 08:34 AM
traxxas?
there are a couple water proof servos.
but mainly not main stream because servos are very eazy to water proof.
its a box .... just tool dip or cover it in epoxy.
simple and much better then traxxas servos. especially when you can use your own futaba or JR servo
ghostofpf1
08-18-2008, 01:08 PM
traxxas?
I've used plasti-dip on servos before but if they get a good dunking the water can enter where the output gear exits the case.I've used grease there in the past with varying degrees of success ...
Ghost
JimClark
08-18-2008, 01:40 PM
Even easier just coat the electronics in corrosion x
Eyekandyboats
08-18-2008, 05:27 PM
if you have issues with water going into the grear box....
make it into a stuffing box. pack that thing with grease..
Dr. Jet
08-18-2008, 05:33 PM
I use the Hitec HS-77BB in all my larger boats (large for me is 4S) because they are waterproof, low profile, and have plenty of torque. For the small stuff I use cheap Chinese servos at less than $10 each. If they get damaged by water, it's not a big deal.
08-19-2008, 04:44 PM
When Mr. Jet pointed me the the 77bb a while back I bought some and they are great. I have been selling them for a while
SweetAccord
09-22-2008, 12:24 AM
Yes I just got one of these analog servos.
They are so far the cheapest ($25.99), lightest 1.23oz (most are 1.3, 1.4, 1.5 oz). Standard size profile to fit standard servo locations (Dimensions: 44x23x25mm / 1.7x0.9x1.0"), very high torque 61.1 oz-in @4.8V, 76.3 oz-in @6.0V), ball bearing, high speed (Speed: .18sec/60° @4.8V .14sec/60° @6.0V, analog servo you can get with Universal Futaba J, Hitec S, JR and Airtronics Z Connector. Great light, powerful, waterproof servo to replace for the standard one that comes with the SuperVee.
The Hobbico CS-59 Servo Lo Profile Aileron BB U is the next best one but is only about a dollar in price difference, and for that I rather have a Hitec one.
Great alternative from the Futaba S9550 Servo Digital Low-Profile or the newer Futaba S9551 Low Profile Digital High Speed/Torq Servo that are $80.00!
mtgoat
09-23-2008, 07:19 PM
I did end up using one of these Traxxas waterproof servos and can now report that they are, in fact, waterproof.
This weekend I accidentally slid the cooling jacket off the end of my motor as I was connecting the batteries.
Thank goodness for styrofoam.
Although the boat was as full of water as it could be when I brought it back to shore, there wasn't the slightest amount of moisture in the servo when I opened it up.
The only disappointing thing about the servo is that it comes with no hardware at all. Not even a servo horn or screw.
