View Full Version : cutting dia of props
sapdforu
07-12-2014, 09:41 PM
How much pitch is lost when cutting props down? Lets say I take octura 457 right and left, cut them down to lets say 45mm, I'm just curious how much pitch will be lost.
07-12-2014, 09:54 PM
Reducing diameter does nothing to the pitch. A smaller diameter prop reduces load and increases rpm. Sometimes reducing diameter will increase rpm and might increase speed.
martin
07-13-2014, 07:55 AM
As Fluid has said, you are not changing the angle of the blades when reducing diameter.
Ronbo
07-23-2014, 05:27 PM
How do we increase pitch, of say a x447r or cnc? Any articles out there on it?
RandyatBBY
07-23-2014, 05:44 PM
You can bend the trailing edge of the prop to pitch it up. I do not know of a article on it others on hear may know.
Ronbo
07-23-2014, 09:29 PM
Im guessing very small bends at trailng edge? How much to bend and where is an experiment?
RandyatBBY
07-24-2014, 09:32 PM
That is about it and the end results are some set records and over and over to boost them.
