View Full Version : swordfish 200a esc parameters HELP!
out of stock
06-23-2014, 03:33 PM
people i need help programming my esc.
its a swordfish 200a opto
my setup:
-leopard 1730kv D
-sf 200a esc
-running on 6s (2 6s packs in parallel)
-x447 prop
here are my parameters
LVC:
*AUTO
*5.0V
*2 CELLS
*7.2V
*8.4V
*3 CELLS
*4 CELLS
*5 CELLS
*6 CELLS
all the way to 20 cells
LVC PER CELL:
*3.0V
*3.1V
*3.2V
*3.3V
*2.5V
*2.6V
*2.7V
*2.8V
*2.9V
BRAKE TYPE:
*NO
*SOFT
*HARD
*NO
TIMING:
*AUTO
*0 DEGREE
*2 DEGREE
*4 DEGREE
*6 DEGREE
*8 DEGREE
*10 DEGREE
*12 DEGREE
*14 DEGREE
*16 DEGREE
*18 DEGREE
*20 DEGREE
*22 DEGREE
*24 DEGREE
*26 DEGREE
*28 DEGREE
*30 DEGREE
*LOW
CUTOFF TYPE:
*HARD
*SOFT
START TYPE:
*STANDARD
*FAST
*SOFT
PWM:
*8KHZ
*12KHz
*16KHZ
PLEASE HELP A BROTHER OUT!!
Rocstar
06-23-2014, 04:58 PM
my setup:
-leopard 1730kv D
-sf 200a esc
-x447 prop
I would suggest starting with a smaller prop. What size motor and what hull?
LVC:
*6 CELLS
LVC PER CELL:
*3.5V
You may have to lower this if the ESC cuts out with a full charge, and time your runs.
BRAKE TYPE:
*NO
TIMING:
*2 DEGREE
CUTOFF TYPE:
*SOFT
START TYPE:
*SOFT
PWM:
*8KHZ
out of stock
06-24-2014, 04:45 AM
outstanding man thanks. im starting with a 445
cf cheetah 4092
