View Full Version : 1/16th Scale Hydro - Which motor?
trialsguy
06-11-2014, 10:33 AM
1/16th Scale Hydro (wood kit from ClassicHydros) - Which motor would you recommend?
There are several versions to pick from (below). :confused1:
Leopard 2845 Motor:
winds/rpm:
2230Kv 4Y (5)
2550Kv 3.5Y (12)
2960Kv 3Y (5)
3300Kv 5D (8)
3650Kv 4.5D (8)
4420Kv 2Y (5)
4700Kv 3.5D (3)
5460Kv 3D (9)
JimClark
06-11-2014, 02:11 PM
I bought the 3650 for mine though i have not used it. Going to use a single 2s lipo also
trialsguy
02-23-2016, 12:07 PM
Jim,
Have you tried the 3650 kV in your 1/16 hydro? How did it work out?
[I am getting ready to build again.]
Thanks.
Dave
JimClark
02-23-2016, 01:02 PM
No I have not used it I have shelved the build.
trialsguy
02-23-2016, 02:07 PM
Ok, Thanks. Did you select the 3650 kV based on past experience with something similar, or was it just a guess at what might work?
JimClark
02-23-2016, 02:37 PM
A guess and also other's recommended it on OSE
What esc and prop would you use that motor with?
JimClark
02-23-2016, 02:52 PM
not really sure but I was going to start with an x430 but maybe an x435? I was going to set it up to turn left so there are limited righthand props to try
trialsguy
02-23-2016, 02:58 PM
I'm also planning to have mine turn left, like the full size ones. I might also try a smaller, vintage scale like turn fin - that way I'd be forced to slow down for the turns, just like they did in the '60's.
JimClark
02-23-2016, 03:04 PM
Here is a gallery I did on my first 1/16th build with some video of it running I can dig up the specs for it
http://www.photosbyjimclark.com/Hobbies/Radio-Control/Boat-Builds/Jims-Build/i-V5QcKCn/0/L/IMG_4285_1-L.jpg (http://www.photosbyjimclark.com/Hobbies/Radio-Control/Boat-Builds/Jims-Build/i-V5QcKCn/A)
trialsguy
02-23-2016, 10:18 PM
Very nice! Thanks Jim!
Dave
02-24-2016, 09:24 AM
What speed is the OP looking for? In the larger format 3650 2-pole motors my club members have used the 3500 Kv motor on 2S and the x440 prop for speeds in the mid 40s. Boats are a bit larger, 23" to 25".
For similar rpm with 4-pole motors I would choose a higher Kv. The 2845/4420 motor should see around 27,000 rpm loaded on the water, with an x430 that should give ~mid-30s which was the speed most of these boats ran with they raced with 7 round cells - I raced them at several APBA FE Nats in the mid-late 90s.
An x435 might increase speed to close to 40 mph if the motor will turn that much prop, but also increase prop walk and handling woes, especially with a tiny turn fin. Note that a turn fin as mounted in the photo above will cause lifting of the inside sponson, the faster you turn the worse it will be.
trialsguy
02-24-2016, 10:02 AM
An x435 might increase speed to close to 40 mph if the motor will turn that much prop, but also increase prop walk and handling woes, especially with a tiny turn fin. Note that a turn fin as mounted in the photo above will cause lifting of the inside sponson, the faster you turn the worse it will be. .
The motor that OSE recommends/sells for their 1/16 Miss K wood hull is the Leopard 2845 Motor (4 pole). They recommend 4420 kV version for 2s, and the 2250 kV for 3s. The details are shown in this link. I plan to run 2s, as the boat is only 22.5" long.
http://www.offshoreelectrics.com/proddetail.php?prod=leo-2845&cat=148 There must be a typo as there is no 2250 kV option shown.
As far as desired speed - I'd like to go real fast, but not spend a huge amount of money doing it. [ I was pretty good at setting up and racing nitro hydros back in the '80s]
NativePaul
02-24-2016, 05:31 PM
I ran a leopard 2860 3400 KV, on 280g 3s 4500mAh, spinning a detounged X432 for a few seasons. The speed in a JAE.12 or 25" wooden cat was about 40mph, with a 5min 20sec runtime or an average of about 45amps.
With only 3550kv on 2s, I doubt an X430 would get up on the plane if it carries a full size 2s pack unless you can build it out of helium. I would have thought an x637 would be more appropriate to the setup, but they are not available southpaw, maybe something from Propshop or ABC.
