View Full Version : swordfish pro+ 300a esc need help!!
out of stock
05-26-2014, 01:07 PM
guys, im kinda stuck at the moment trying to figure out how to program my sf 300a esc. :confused2:
i dont know how to set it. would any of you happen to know what settings it needs to be on?
my setup:
segad 56"
-leopard 5698 835Kv 4D 8mm Shaft
-8s (4x 4s 5000's)
-70mm aluminum prop
You have the Swordfish program box? Where in Fl are you?
out of stock
05-26-2014, 02:13 PM
fort myers fl. i have the usb link that came with it along with the software.
photohoward1
05-26-2014, 02:27 PM
Did you install the software? If you didn't it has to run on any drive but the C:/ drive... Auto timing is what I use. and set it for 8s....No Brake, No reverse, Linear throttle. What else would you like to know.
IMO you might want to start with a smaller prop. It should work but maybe sneak up to it.
out of stock
05-26-2014, 05:14 PM
very relevent thank you. i will have further questions coming soon as i dont have the software on me. its on a friends laptop.
there were several other settings. i will get back tomorrow thnx alot.
grsboats
05-26-2014, 05:51 PM
With software it won't be difficult to set properly this esc...I have two working great. Gill
out of stock
05-26-2014, 10:17 PM
ill just need someone to give me a run down on each setting for my given setup. thank you all.
out of stock
06-03-2014, 02:17 PM
okay i need someones help getting this esc programmed.
my friend and i programmed it and it seemed to run okay however when i give full throttle and let go it stops instantly. isnt it suppose to stop softly?
LEOPARD 5698 D 835KV
8S
parameter setting
LVC = auto/5.0v/2cells/7.2v/8.4v/3cells/4cells...all the way to 20cells. (obviously 8cells lol)
BRAKE TYPES = NO BRAKE/SOFT BRAKE/HARD BRAKE (currently on soft brake)
CUTOFF TYPE = SOFT CUTOFF/HARD CUTOFF
PWM RATE = 8KHZ/12KHZ/16KHZ (currenly at 8KHZ)
CUTOFF VOLTAGE/CELL = (I havent set this cretiria yet. my options are 2.5v to 3.3v)
TIMING ADVANCE = LOW/MIDDLE/AUTO/ 0 DEGREES TO 30 DEGREES
START UP TYPE = SOFT/STANDARD/FAST
THROTLLE RANGE = (IT DOESNT LET ME SELECT THIS ALTHOUGH IT SAYS FADED "520" NUMBER ON IT)
guys help me out here. thanks
Rocstar
06-03-2014, 02:22 PM
Change to No Brake. Throttle will be proportional. Also set the startup to Soft.
photohoward1
06-03-2014, 02:23 PM
No brake!
out of stock
06-03-2014, 02:48 PM
thanks but what about everything else?
Rocstar
06-03-2014, 03:27 PM
Soft cutoff. Cutoff voltage you can set to 3.2v but if you experience the controller limiting throttle during acceleration you may have to lower this value and time your runs. Timing, I like to set at around 2° for D wind.
kevinpratt823
06-03-2014, 03:38 PM
Can anybody explain to me how this "auto timing" works? I've always been reluctant to use it, what does it base the automatic setting on?
out of stock
06-03-2014, 03:46 PM
^ good question
