View Full Version : New Swordfish 120 Stops running?
kacordy
05-18-2014, 10:20 PM
I'm trying out my first SF 120 plus. If I run a prop bigger than a 442 it stops running after about a 10 second run. It comes to a stop and then restarts. Is it the Temp sensor shutting it down? Phil Thomas, Phil's recommended set-up, 2030 etc. I will order the link so I can check my data. Very Disappointing. Props that shut it down x-445, M-445, M-545, H-7. End bell is 120, Hyperions at 95. How are you guys running in the low 50's????
Thanks for the Advice, Allen
photohoward1
05-18-2014, 10:33 PM
What is your Lipo Cut off set at?
flraptor07
05-18-2014, 10:40 PM
Either the link or it's easier to use the programer, you can change settings at the water http://www.offshoreelectrics.com/proddetail.php?prod=hef-programbox What boat are you running?
kacordy
05-18-2014, 10:45 PM
I have it in "Auto" with the programming box. timing is 10, fast start. I'm running 2 packs. 4s2p I believe is the term.
Allen
flraptor07
05-18-2014, 10:57 PM
Allen
Take it off Auto and set it for 4s and set the LVC @ 3.0, set normal start, and timing @ 5deg. (low) see what happens
kacordy
05-18-2014, 10:59 PM
Perfect, I will give that a shot.
Allen
