View Full Version : Has anyone used these batteries?
BajaOutlaw33
05-17-2014, 04:39 PM
I found these on Ebay. Im having a problem with my T-180 and the LVC. I have posted before about it and one of the suggestions was to replace my 3s 25-50c 6000Mah nano techs. Curious if anyone has used these batteries.
http://www.ebay.com/itm/121059205144?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
kevinpratt823
05-17-2014, 04:47 PM
Never seen them, I'd go with Dinogy's personally.
Brushless55
05-17-2014, 05:09 PM
looks like a new name, not sure who's cells they use?
fellow racer who has good prices here
http://www.mojoracingproducts.com/
JimClark
05-17-2014, 05:57 PM
Sounds like you are running too long
BajaOutlaw33
05-17-2014, 07:50 PM
My LVC cuts in about 30 seconds into my run. Known problem with the t-180. I have auto cell off to. I time my runs but I use different props and run in different conditions so I was going through batteries quite a bit.
Brushless55
05-18-2014, 12:47 AM
What's your setup?
you may need an external bec or battery pack for the esc...
I know the Nano 25C packs are not all that strong specially in FE boating
BajaOutlaw33
05-18-2014, 06:09 AM
What's your setup?
Here's the thread I started to come to the realization its the batteries.
http://forums.offshoreelectrics.com/showthread.php?43600-I-need-help-with-my-boat&highlight=
kevinpratt823
05-18-2014, 06:51 AM
If/when you get the LVC disabled and sorted out, IMO that motor and prop on 6s will be quite a load to draw from (2) 3s in series, even if they were good quality high c rated packs, be very cautious otherwise you'll puff them quick. Personally, when I ran a similar setup I used (2) 6s in paralell.
