View Full Version : Blueprinting Tutorial
BHChieftain
05-15-2014, 09:10 AM
Hi,
I put together a tutorial on blueprinting, videos are located here:
http://www.rcchiefhobbies.com/Tutorials.html
This covers strut, rudder, and blueprinting, it's for the Miss Geico/Blackjack but applicable for any cat.
Chief
skeeler
07-17-2014, 08:56 AM
Those are very useful videos. Thanks.
Does a similar approach work for mono-hulls?
BHChieftain
07-24-2014, 08:51 AM
I've never had to "blueprint" a mono hull, but if you had any damage to the bottom of the hull the marine epoxy putty would be great for repair.
Chief
bikergreen
07-26-2014, 11:45 AM
I have always wondered about the right process for this, I'm sure I could sort it out but who knows what the end result would be. Awesome you took the time to put this together!
Thanks!
revoltrunner
09-19-2014, 08:51 AM
Thanks it really helped my MG
TRUCKPULL
03-27-2015, 11:15 PM
James
Could you give us some information on the side to side profile for the cat sponsons??
What Degree angle ( Dihedral) on the sponsons for Offshore racing??
Should there be a difference in the angle of the left and right sponson the same as on a sport hydro for Oval racing??
Larry
boilo56
07-19-2015, 09:57 PM
Hi, i would like to know if it is possible to blueprint this kind of ride pads and how please:134685134686134687
Thank you!
Beaux
02-07-2016, 12:08 PM
Hi Chietain, I,m new to the hobby but not to boats. I just did this to mine,it,s a f1 hornet and the sponsons look so much better and sharper it really hooks in the corners now. I,m running A 3650 2930kv, it is running 50ish. Thanks again.
ray schrauwen
02-07-2016, 02:40 PM
Mine is rocking, I'll need to redo it. Need some marine Rx too. Wish I saw this long ago. Thanks Chief !
Beaux
02-07-2016, 02:53 PM
I used fiber glass resin and tape on mine. It took about 3 passes to get a good shrp corner.
ray schrauwen
02-07-2016, 03:42 PM
Could not find marine Rx on eBay just marinetex.
dmitry100
02-08-2016, 02:27 PM
Would making your ride pad edges as sharp as possible (and ride pads even) make a big difference in terms of speed for SAW?
I think my Mystic has a rather thick gel coat which I think resulted in "round" or "dull" edges around the ride pads... and the gel coat on the ride pads seem to have this unevenness to them like there is high and low points in there.
Can this unevenness affect speed as well? or is it more to do with overall stability, lift, etc...
TRUCKPULL
02-08-2016, 05:43 PM
Ray
Marine Rx and marinetex are the same thing.
One is a West Marine brand name.
The other is the same thing from the company that makes it and sells it to West Marine.
I get mine at my local marina - store.
Larry
dmitry100
02-08-2016, 05:54 PM
Wouldn't it work to just even out the ride pads by sanding the initial layer of gel coat?
Not sure what MarineRX is to be used for in that case...
rdcracer
02-09-2016, 11:52 AM
I my case when I did my Blackjack 29 the rear pad was concave. I would have had to remove too much material to get it level. It also builds up the edges so you can get rid of the rounded edges and sand sharp. It made an incredible difference in handling to mine.
dmitry100
02-09-2016, 12:43 PM
Do you know if it helped with speed at all?
JimClark
02-09-2016, 02:13 PM
Guys this is an old thread and haven't seen (http://forums.offshoreelectrics.com/member.php?3205-BHChieftain) BHChieftain (http://forums.offshoreelectrics.com/member.php?3205-BHChieftain) in a while here. He is fairly active on RC Groups in the racing boat forum though
dmitry100
02-09-2016, 02:36 PM
boilo56: Ditch the plastic props :) Go with some dasboata octura's!
or at the very least some CNC props...
