View Full Version : Delta Force 29 newbie build
danallen
05-13-2014, 09:31 PM
Greetings everyone! I thought I would post up my first steps into non-rtr boating. I realize that this is pretty simple stuff for most of you guys, but it was fairly intimidating for me.
Some history:
A couple weeks ago I crashed my Aquacraft Revolt 30 pretty hard into some rocks and severely damaged the hull.:doh:
Thread about it here: http://forums.offshoreelectrics.com/showthread.php?46464-Crashed-boat-need-advice-please
Anyway, I decided to buy the DF 29 hull, and a few other associated items from our host. (Extremely pleased with OSE's service by the way!:thumbup1:)
The idea was a budget build using the hardware and electronics from the Revolt in the new hull.
Equipment specs:
Delta Force 29 hull
Aquacraft Revolt hardware (grimracer?)
Aquacraft 60amp esc
Aquacraft 3656 1800kv 6-pole motor
4s 5100mah lipo
Octura x445 prop
Savox 1258tg servo (I know it's overkill but I had it laying around)
Airtronics 92524 reciever and MT4S transmitter
On to the pictures! ...
First a couple shots comparing the size difference between the two hull. (The DF29 is .5" shorter and about 1" wider than the Revolt.
http://i332.photobucket.com/albums/m355/Danallen350z/2EB33444-5299-4CC7-80EB-0D6F346463E1_zpsc7i1ch0m.jpg
http://i332.photobucket.com/albums/m355/Danallen350z/AAFFD684-3F5D-41D3-95EA-E87EDA7A693E_zpsqautxtd2.jpg
danallen
05-13-2014, 09:34 PM
Having never built a boat before, I wasn't sure where to start.:confused2: I decided to begin with simply marking a centerline on the transom as a reference point for the hardware.
http://i332.photobucket.com/albums/m355/Danallen350z/B5BE1D36-3814-4B7B-8A02-F58BD02DC0F9_zps6z8nxzlp.jpg
And drilled my first hole in my virgin hull.
http://i332.photobucket.com/albums/m355/Danallen350z/EC20DC48-3AA6-49D4-989E-1DEB4754FAEF_zpsnmtkntvb.jpg
After a couple of hours of carefully measuring everything... and a few wild guesses thrown in for luck, the stern was starting to look near completion.
http://i332.photobucket.com/albums/m355/Danallen350z/0AE42918-3097-44E8-B959-6A51B7033C33_zpsrbjsvurt.jpg
danallen
05-13-2014, 09:35 PM
Well, I had no idea where to mount the electronics so off to google for some info (because the internet is always right. ...right?:wink:) I read that most mono hulls seem to like the cg around 28%-30% so thats what I shot for. Pretty much I just set everything in place and slightly adjusted everything around until I was happy with the weight balance. With my 4S battery all the way back the cg is about 25%, but I ordered 350mm battery tray with the hull, so there is plenty of room to move it forward to adjust the cg.
http://i332.photobucket.com/albums/m355/Danallen350z/E5DE9B25-20A9-469E-AE23-B5E971012BBE_zpsrhysxlpl.jpg
http://i332.photobucket.com/albums/m355/Danallen350z/963F4ED0-1275-472F-87F2-755F313618A0_zpsjb9h0iz6.jpg
danallen
05-13-2014, 09:36 PM
At last I was nearing completion. I finished a few things, slapped some stickers on the hull and took a few completion pictures. :buttrock:
http://i332.photobucket.com/albums/m355/Danallen350z/2E53F270-7CA7-45E1-9991-4E79F2AFEC8B_zps38zczqle.jpg
http://i332.photobucket.com/albums/m355/Danallen350z/25E0185F-BE54-45D7-B2AA-1F2E208A04AF_zpshyc9pfnw.jpg
http://i332.photobucket.com/albums/m355/Danallen350z/90D6C095-E5F8-4A44-BD76-932A527A9DF7_zpsnxz0kscb.jpg
http://i332.photobucket.com/albums/m355/Danallen350z/53A9930B-42C9-471D-A67D-8FFFAC88B234_zpsu1nerwii.jpg
Luck as a Constant
05-13-2014, 09:45 PM
looks mint
danallen
11-04-2014, 05:25 PM
Unfortunately, I have only been able to run the boat twice since building it. Very busy with work, but such is the life of a military man.
It is fast! quite a bit faster than my friends stock revolt. It accelerates great and turns great, but at high speed I cannot hold full throttle in a straight line for more than a second or two or it wheelies out of the water. I have since adjusted the prop down a few degrees, hopefully that will settle it down some (yet to be tested).
Also, I've made a couple of upgrades/changes since building the boat that I thought I'd share.
I sold the AQ 60a ESC and ordered a seaking 180a v3 from our host to replace it. Also, the Savox servo got removed to serve in my Tekno SCT, and a Hitec HS-5646WP was installed in its place. Lastly I replaced the 92524 receiver with an RX-461 that has telemetry so I can keep better track of motor temps while running. Unfortunately, the Seaking 180's bec only goes to 6.0v and I'd like to run at 7.2v so I may add an external bec in the future. I'm also toying with the idea of buying a receiver box, as opposed to shoe glueing by receiver, cap and maybe ext-bec to the hull like I have now, any recommendations?
One last question; What timing does the AQ 3656 1800kv 6-pole motor like?
Stay tuned for the next update when I get the new ESC installed and get some testing done.
Bye for now!
-Dan
P.S. a pic of the new servo and receiver (the small nylon tie on the motor is holding the telemetry temp sensor) minus ESC:
http://i332.photobucket.com/albums/m355/Danallen350z/010e9999b488e0f2874dccd4ae318d10_zpse8836727.jpg
785boats
11-04-2014, 07:05 PM
Nice clean build there Dan.
But one thing worries me. Having the motor mount just glued to the hull on its own can usually result in it tearing away in a good tumble. The battery tray too.
I usually epoxy a piece of 1/4" carbon fiber tube from the transom, against the motor mount, & up to the front of the battery tray. This bonds everything to the hull a lot more strongly. And it also makes the hull & motor mount much more rigid. Sand the areas that epoxy will contact, & wipe it down with Acetone to get rid of the waxy film in the hull. Nothing sticks to that very well. Works in cats & hydros too.
Here's a couple of pics to give you an idea.
danallen
11-04-2014, 07:37 PM
Thanks for the tip, Ill look into some CF tubes. Is there a certain brand or strength I should look for? Or just any 1/4 cf tube.
Also, Do you epoxy the whole thing or just every couple inches?
785boats
11-04-2014, 08:58 PM
No special brand. A good thick wall or even a rod. I generally salvage my sons broken arrow shafts & use them. If you have a local hobby shop, they usually sell carbon tubes. Especially if they sell kite making stuff. I've even used tubes from Hobbyking. Plenty strong enough.
I Epoxy all the way, with plenty on the engine mounts & battery tray.
Be sure to sand the rods with some 240 grit, or so, paper too.
danallen
11-05-2014, 06:01 PM
I bought some 1/4" CF tube at the hobby store and installed it today. The motor mount is much more sturdy now.
http://i332.photobucket.com/albums/m355/Danallen350z/71157c86ef1c194a4ffbde003ed772ac_zps7c577eeb.jpg
785boats
11-05-2014, 07:05 PM
There ya go.
danallen
11-06-2014, 06:44 PM
Today I got my new ESC installed. I also replaced the esc/motor 4mm bullets with 6.5mm bullets. I honestly never felt any heat after a run with the 4mm ones, but I don't want a problem in the future. Especially since I'm considering upgrading to a bigger motor, but that topic is for another time.
I did some googling and found that the stock AQ 60a esc has its timing set at 11. So I set the timing on the Seaking to 11.25, it was the closest setting available. I suspect AQ knows their motors better than I do, so why change it.
Next, I'm thinking about a new motor. The castle 1515 2200kv is the one in sight right now. We'll see, I would like to run the boat as is a few times and learn a bit more about trim/strut adjustments before I put in a bigger motor.
Thanks for reading.
-Dan
Edit: I forgot, I also read that it was a good idea to pour some epoxy into the tip of the bow. So I did that as well. Not alot just about 3/8".
http://i332.photobucket.com/albums/m355/Danallen350z/f3a187082cf58d95504c268453c71124_zpse3e29fb6.jpg
cuppa
11-14-2014, 03:30 AM
Nice build Sir
785boats
11-14-2014, 03:19 PM
Dan.
Cuppa is 100% right.
For a first build you did everything pretty much spot on.
Congratulations on a job well done.:thumbup:
Of course you do understand that videos are a compulsory part of the deal, don't you.:biggrin:
PowerDemon
11-14-2014, 05:52 PM
That is a fine build! Especially as your first one. Congrats!
