View Full Version : questions on charger settings for a 5s1p
pugman2
05-05-2014, 10:16 PM
seen some batts im thinking of buying not sure how to charge them if I get them . most of what I see has 1sp for example one pack im looking at is a turnigy 8000mah 5s1p do you charge it at 5s 8000mah ? when you have 1sp I am confused
LiPo Power
05-06-2014, 09:01 AM
Check the battery specs, it will tell you at what rate you can charge...
pugman2
05-06-2014, 06:07 PM
do i charge like a regular 5s if its 5s1p?
photohoward1
05-06-2014, 06:54 PM
Yes
LiPo Power
05-06-2014, 10:50 PM
Yes
pugman2
05-27-2014, 10:47 AM
my charger is a hyperion i think it autmaticly puts in charge rate not sure i set it at lipo 8000mah and 5s and hit enter hope this is right
785boats
05-27-2014, 02:58 PM
Yes.
My Hyperion Duo would automatically charge at 8 Amps with that setting. That's a 1C rate. But the Amps can be adjusted separately up or down in the menu if so desired, while still leaving the capacity at 8000mah.
I don't know what model Hyperion charger you have, but I think it would have the same function.
pugman2
05-27-2014, 06:29 PM
just dont want to hurt anything saved my pennys awhile for that pack
785boats
05-28-2014, 03:24 AM
In the menu where you set the 8000mah capacity, scroll down to the next parameter & see what the current charge is set at. If it is set at 8 amps then you are fine. As long as your power supply is capable of supplying the charger at least 10 Amps.
What model charger do you have? The instructions should have the details in them.
Cheers.
Paul.
kevinpratt823
05-29-2014, 07:09 PM
Even if the pack said 5s2p, you still charge it as a 5s/8000mah. It only refers to the configuration of the cells within the pack to achieve the ratings. A 5s1p has (5) single 8000 mah cells, a 5s2p has (10) 4000 mah cells in series paralell (5 pairs, each pair in paralell, then all 5 pairs in series with each other) The end result is the same.
pugman2
05-30-2014, 05:49 AM
thanks
