View Full Version : STS-250 Shaft Tube Seal .250
ReddyWatts
04-18-2014, 07:44 PM
http://aeromarinerc.myshopify.com/products/sts-250-shaft-tube-seal-250-1-4-size
properchopper
04-18-2014, 08:23 PM
Here's the breakdown :
A bearing is used so the other side of the piece with the o-ring rotates with the flex (preventing o-ring wear):
114452
The o-ring side :
114453
exploded view :
114454
In place :
114455
Also has a lube port, and the retainer ring set-screws to the flex to hold all three pieces together and as a byproduct it retains the flex if it comes loose from the collet
Rather clever !! :thumbup1:
longballlumber
04-18-2014, 10:33 PM
Where is my buddy Jimmy when I need'm... (inside joke)
That system is very dependent that you don't have a collet with horrible run-out (or misalignment for that matter)! Otherwise it's going to translate all of the misalignment into the stuffing tube, shaking the dog poo out of the stuffing tube/rest of the hull.
Later
Ball
jfrancisco892
04-20-2014, 12:53 PM
Don't get me started on runout lol.
ron1950
04-20-2014, 04:38 PM
I like it...there is a .187 version also
kfxguy
04-20-2014, 05:44 PM
http://kintecracing.com/
I was thinking about trying one but I wasn't sure if it was extra drag. If not I'll put on on all my boats. Anyone know if it's more drag?
properchopper
04-20-2014, 06:01 PM
Since the o-ring does not stand still with the flex rotating inside of it (see post #2)- it rotates with the flex, the only "drag" is that of the ball bearing. The only downside I can potentially see is that the retaining ring setscrews to the flex and has to be loosened to pull/lube the flex each time.
properchopper
04-20-2014, 06:07 PM
114509
SloHD
04-20-2014, 06:26 PM
Isn't that the point of the grease fitting though? I've never had a boat with a grease fitting so excuse my ignorance...
ron1950
04-27-2014, 02:22 PM
hey tony have you tried this thing yet? what ya think?
properchopper
04-27-2014, 02:54 PM
Not yet - none of my boats get water up the shaft. I have a build coming up soon where I'll use it 'tho
Allrc
05-23-2014, 08:53 PM
I got a mess of these in and they sold out very quickly. I'm waiting for more. My experience with them says;
1. I found its much better with a 50/50 mixture of ATF and a heavy oil like STP between runs. I don't like putting actual lithium grease through it. (Or any other oiler I've ever used)
2. I found they work best with a clamp on collet as opposed to a floating square drive like I use in my nitro 1/8 scale. If you use on a square drive the cable clamp moves slightly as the cable floats. I don't like that.
Remy put a lot of thought into these and I think he found a winner.
Bill Brandt
kevinpratt823
05-24-2014, 06:28 AM
If it would work with grease I'd jump on it. Perhaps you could squeeze it in while you rev the prop a bit to let the shaft work it down into the tube. I put a stuffing tube bracket with an oiler/reservior setup in my Sniper, and I don't use it now. I found that on the first run the oil/ATF would break down any grease in there and the flex would come out clean and somewhat dry, while I could do 2-3 runs with grease alone and still have a good layer in there when I was done.
I just installed two of the .187 size ones on my fantasm and I like them pretty well other than when you go to put oil in the nipple some of it always pushes it's way through the actual bearing itself and comes out inside of the boat. I only have run these on the bench so far but my drive line seems nice and smooth and the resistance was very minimal. I will report more on these after I actually run them in the lake this weekend. I also didnt mention that you need to debur the insides of these before installation as there was some loose aluminum in both of mine that was left from machining.
Okay, I've had enough runs with the stuffing tube seals now to say that im anfan of them and will install them on most if not all of my future builds. Ive spun them at over 35k rpms and had no problems or water intrusion from the stuffing tube. I just wish someone would get the .187ones in stock again so that I can order more
kfxguy
06-29-2014, 08:35 PM
I'm gonna try it out now.....thx
Allrc
06-29-2014, 10:08 PM
Yeah, there's some trouble getting that bearing back in stock. They're all on back order.
Bill
jcald2000
06-30-2014, 06:58 AM
order bearing that have seal on one side , no more oil in the boat and easier to get.
ron1950
06-30-2014, 05:41 PM
anyone try ordering one from aeromarine I beleave there web site shows they have them in stock
My friend ordered his direct and had no problems
Tamelesstgr
08-05-2015, 01:29 PM
Any updates on running these since 2014?
kfxguy
08-05-2015, 01:40 PM
I stopped using them
dmitry100
08-18-2015, 04:59 PM
The bearings in mine exploded. Aero said they'll send out a new one but haven't received it yet. They seem to be good for oiling your driveline though even if your not using it with the flex saver and other parts etc, I think.
It actually ended up locking up my driveline... so if I didn't notice the busted bearing in time it would have easily caused an entire meltdown in that side.
I think it's good for some setups where water runout is a huge issue and/or lower rpm stuff, otherwise... im sure its just an extra thing to break and cause havoc.
I'm not the only one with these bearing issues-- I have talked to at least 1 other person that had the same thing happen and it was in the similar kind of a high RPM catamaran setup as mine.
The fact that these replacement bearings are no where else to be found is something to consider.
