Prop prob
Prop prob
With a file
At least that's what I would try first
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still... -
Always have bought my props on advice and always sharpened and balanced. So have no prop working experience. What type of file and just try and round out the edge? Know you detongue props in that area and don't wanna screw anything up. Boat is finally running perfect. Any vids maybe on you tube on how to work a prop? Thx JeffComment
well, firstly, i would try to bend back any material that may still be there, then grab a fine metal file from hardware store and slowly work the blade back to health. you should have a balancer tho. look in the info section of this website for prop info. good stuffThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
Jeff, while I have not have to work on my props, I had similar problems before, as said, before filing away, I place the nicked area against a glass table top and pressing the blade against the glass until everything is as smooth as possible, you need to observe the curve on the good side and not deform the problematic side too much, always back up the blade with your finger. Sometimes I find something round---like the barrel of a pen or marker and "roll" the uneven area back to a more acceptable degree.
I don't use a file personally, no matter how fine they are, the thin material is too fraigile to be filed. I use above 200 grit sand paper, actually 320 or 400 would be ok, I carefully smooth out the leading edge. The key word is "to smooth out", not taking away too much. Depending how much is ""smoothed away", I would recheck the balance and might have to go over on the good side to even things out.Too many boats, not enough time...Comment
Jeff, get yourself a small file set from the depot. Like they sell on ose and kintec. (I think ose sells a set, I know kintec does)
That thing is barely nic'd. Just file it back nice and round and run it. Try to file as lightly in that area as possible.Comment
