View Full Version : Steering Servo came loose
Tom899
03-25-2014, 01:39 AM
On my Revolt 30 the steering servo came loose from the hull. What is the best epoxy to use to reattach?
Thanks,
Tom
srislash
03-25-2014, 08:17 AM
I use System Three but West Systems is good. Really any epoxy is fine. The longer cure will hold better than the 15, or 30 min stuff. Did it break clean from the hull or leave jagged bits?
capnswanny
03-25-2014, 08:52 AM
If it's a clean break like mine was, rough up the hull and bottom of the servo plate with 120 grit or rougher sandpaper, wipe with acetone or alcohol, then epoxy as suggested.
I reattached mine a year ago, still holding strong. They didn't prep the mount at the factory...it was shiny smooth when it popped loose.
Corey
Tom899
03-25-2014, 09:27 AM
Mine is a clean break, and shiny
Grimracer
03-25-2014, 03:42 PM
I use Shoe Goo... (I can not be around Epoxys).. both work well!
Grim
Tom899
03-25-2014, 05:50 PM
Thanks, I think I'll give Shoe Goo a try
Tom899
07-06-2014, 01:12 PM
By the way, Shoo Goo works great!
