View Full Version : Best brushless motor and esc for 1/8 Hydro
BAZCNG
03-10-2014, 12:18 PM
In my next project I am going to build an 1/8 electric hydro. I am open for suggestion on the best motor esc combination for this.
RaceMechaniX
03-10-2014, 01:25 PM
Are you intending to race this within a particular organization? Some has specific rules for motor and batteries which limit what you can select.
BAZCNG
03-10-2014, 02:46 PM
I have been recommended a TP-5840 inrunner 7Y 850KV and a aquacraft 240 esc.
03-10-2014, 03:29 PM
I assume you will not be formally racing this hydro but instead doing some fun running. What voltage do you plan to use? What hull? What are your speed and run time expectations? Your budget? To fully enjoy a model of this size you will need a fairly large pond which is not too windy or rough.
BAZCNG
03-10-2014, 07:03 PM
I have every intention of racing .It will be on 100 mts coarse and flat water. The person that recomended that set up racing a lot. He is a Kiwi like me and has raced in the stated
RaceMechaniX
03-10-2014, 07:41 PM
Do the Kiwi's have the same rules as the Aussie's? 1P only?
TG
Peter A
03-10-2014, 07:54 PM
Hi Barry
I plan to build a 1/8 to compete in Suha (NZ) racing next year. Mostly they run 10s setups here and NEU motors are popular, but I have a more limited budget so a TP power motor will probably be a goer. I have a couple of smaller TPs and they go well. The aquacraft 240A should be ok, or perhaps a swordfish 240A. At the end of the day your budget and prferences are what will determine the choice. Cheaper motors etc have been run in the past with success, but like with any boat the setup, prop, etc will all be important factors in how well it runs. Your current direction however should get you racing/ having fun. You can always upgrade in a year or two.
Peter A
03-10-2014, 07:59 PM
Check out
www.suha.co.nz
www.nzmpba.co.nz
for rules.
@Tyler, we can run 2P but most run 1P, maybe more of a budget/room/weight thing.
flraptor07
03-10-2014, 09:52 PM
I've got two 1/8th Sport Hydros both have Swordfish 240 Pro Plus ESCs one has a Leopard 5698 910kv and the other has a Leopard 56110 950kv both are on 10s 2p here's a vid of a little blowover lol https://www.youtube.com/watch?v=AQVFAPL1MFs&feature=youtu.be
RaceMechaniX
03-11-2014, 02:14 AM
Thanks Peter,
A very popular set-up here is the Neu 1527 1.5Y on 10S. You could also run a Castle 2028 on 8S or 10S. Look for a 1527 size motor from HET or Leopard if on a budget and make sure the ESC you purchase is up to the task.
TG
don ferrette
03-23-2014, 09:33 AM
Thanks Peter,
TG
Tyler is spot on here, the 1527 1.5Y on 10S is the shiznit for 1/8th scales in what we've found to date. :thumbup1:
785boats
03-23-2014, 05:41 PM
I'm not suggesting that this is the best setup, but to save money I'm running 8s 1p in mine because I have a lot of 4s packs & it was a smallish 1/8 scale at 42". Also to save money I had a Neu 1527/1Y 1250kv motor so I've put that in it with a Swordfish 240A.
A more ideal kv on 8s would be around 1000- 1100kv to drop the revs a bit & use a larger prop.
Here she is testing a Prather s240 prop. I've ended up using a Prather s235 prop now.
https://www.youtube.com/watch?v=fT9AIFACFGo&list=UUmckFCp5vHpw83p9Hn-l1hg
twissted
04-27-2014, 07:23 PM
Has anyone tried the TP-4070 5Y 880kv motor? Or the tp4060 6Y 930 kv?
I have to try this Aquacraft 240 controller!
heraldoboldrin
08-05-2014, 08:27 PM
Where can i find a 1/6 Hydroplane hull?
Brushless55
08-05-2014, 08:44 PM
Thanks Peter,
TG
This class looks like a lot of fun!
what kind of speeds do these boats run down the straights ?
Doug Smock
08-05-2014, 09:47 PM
Never checked.. Fast enough to be an absolute blast!!
In the upper 50s low 60s I'd guess.
https://www.youtube.com/watch?v=zuk-d6chMyg
https://www.youtube.com/watch?v=Y35uoH2t2RM
photohoward1
08-05-2014, 09:54 PM
While we are showing off. This was 2006....
https://www.youtube.com/watch?v=NSP3x-SKfT0
Doug Smock
08-05-2014, 10:02 PM
Nice! "Love that sound"
Brushless55
08-06-2014, 10:26 AM
Fast enough for me!
those are cool...
I've thought about a Brushless Backlash but this is better IMO
785boats
08-06-2014, 10:47 AM
I've managed to top 70mph with mine. Surprised the hell out of me.
https://www.youtube.com/channel/UCmckFCp5vHpw83p9Hn-l1hg
:drool:...At the videos. That is all.
Brushless55
08-06-2014, 04:07 PM
I didn't realize the rpms you are running on 8s! KILLER :rockon2:
madmikepags
08-08-2014, 09:44 AM
I have to agree w/ Tyler and Fluid the 1527/1.5y on 10S is the best combo, and the current national champion setup. I've been running this setup in my scales for 6+ years and they are flawless and with the newer batteries we are going faster and faster. Doug Twaits scale at the nats this year was probably the fastest scale boat I've ever seen.
bracka69
01-25-2015, 09:00 PM
Evening gents, I just bought a 1/8 Exceed gas hydro hull that I plan to put brushless. I see where someone said a Castle 2028 would be an ok motor for this hull. Is that correct? Also should I upgrade the hardware or can I get away using the hardware that comes on the gas hydros? Thanks!!!
