when I put MC away at the end of summer everything was working fine. Just tried to run, hook up the batts the esc beeps one time go full throttle to arm and no beeps. The steering works but no motor. Any ideas? Batts in radio and for the boat are both ok.
01-24-2014, 05:40 PM
Most likely the throttle trim on the transmitter has been moved. You may have to experiment to get it back.
Ya tried that to. I switched rec and radio from my SV and everything is good .So esc is good .SO must be radio or rec.????? Any easy way to test?
