View Full Version : Swordfish Pro 200 and 220
Chilli
01-07-2014, 11:31 PM
Steve recently got some Swordfish controllers in stock. What's the word on the Pro 200 and 220 controllers? I'm debating trying one out for a P-Mono heat racer. Anyone have any input??
srislash
01-08-2014, 01:09 AM
Got a couple 220's, seem great so far. Watch the hard start setting. If you go to putter in it can jump.
HTVboats
01-08-2014, 08:19 AM
I bought two of the early 220's from KBR and for whatever reason they would cut out similar to when you hit low volts on "D" winds. No problem with "Y" motors. Other than that I have had good results with SF200 esc's. 300a not so much.
Mic
flraptor07
01-09-2014, 12:02 AM
I've got 220 pro pluses in three of my boats and all run great Y and D wind motors. I've also got a pair of 200 pro pluses for a Cheetah twin build I'm doing, haven't run those yet but I'm sure those will work fine too.
dennislawler11
04-29-2014, 11:42 PM
i have a leapord 4082 that keeps cutting out with the sf 220+ what is doing that?
flraptor07
04-30-2014, 08:49 AM
What do you have the LVC set at? and what is the rest of the setup on the boat? KV, Prop, size of boat, batteries, ETC.?
dennislawler11
04-30-2014, 09:52 AM
it is a 34 inch tunnel 2000 kv x447 prop 4s 5000mah 45-90c it says the lvc should defalt to 3.2. my usb link for the esc should be here tommorow.
flraptor07
04-30-2014, 12:01 PM
Everybody is different but I set my LVC @ 3.0 volts. What kind of temps is it running? That might be a little too much prop for that setup try backing up to a 44 or 45mm prop and see if it still does it
dennislawler11
04-30-2014, 01:40 PM
the temp seemed normal i will try backing off the prop thank you
dennislawler11
04-30-2014, 03:16 PM
it does seem to cut out even out of the water. is that normal?
427srule
04-30-2014, 07:30 PM
Dennis,
I am running a SF220+ with data logging and 4s in a few different boats.
Had a few instances were the boat stopped during testing. I checked the amount of amps and it was as high as 280. This controller is only rated for 220 amps continuous. I had way too much prop.
When I propped down everything was good.
Check it out
dennislawler11
04-30-2014, 11:27 PM
would it do that even out of the water?
flraptor07
05-01-2014, 09:05 AM
It shouldn't do it out of the water because there's no load on it, if it's doing it out of the water you got other issuses
T.S.Davis
05-01-2014, 09:39 AM
What kind of experience are people having racing these? Guys have them in our club. I've never really checked them out though.
Be careful with the LVC on good cells. I set mine at 3v too but my GP packs and even some of my oldest Hyperians will deliver 3 volts until the tank is stone empty.
iridebikes247
05-01-2014, 10:36 AM
I ditched the LVC cut off with my seaking escs now they're fine. With high quality packs like dinogy I didn't have a problem but with my zippy packs I was hitting lvc.
T.S.Davis
05-01-2014, 11:00 AM
Is the timing adjustable in 1 degree increments on these?
flraptor07
05-01-2014, 11:17 AM
The newer versions that I have (after 12/4/12) are adjustable in 2 deg. increments. I'm sure everything you'd get new will be this way, I've got 6 or so boats with these in them and have had zero problems out of any of them.
twissted
05-01-2014, 06:30 PM
I just bought 1 of 2 SF-200 8s for my modified Zonda that is using the TP4050 2220kv motors I will be using the esc on 6s and some lipos that no one here has tried in boats the SMC 6500 70-140c race formula hard packs that are used in cars.
