View Full Version : upgrading my charger
plpflyboy
11-06-2013, 11:34 AM
Right now I have a bantam bc6 charger and it takes forever to get all of my lipo's charged. They range from 2s to 4s 5000's. I am looking at upgrading to a large multi charger setup and do some parallel charging. One I like is the ICharger 308duo with a pair of server power supplies. Has anyone used this setup or have opinions about them? I am also open to looking at others that have close to the same capabilities. I do understand that to parallel charge the batteries must be the same cell count and mah rating. Thanks for the help.
rickwess
11-06-2013, 12:28 PM
I use a ThunderPower 820 feed by a Mean-well power supply.
I don't know anything about the ICharger but I know ProgressiveRC carries that family of chargers. I use one of ProgressiveRC's cases and in dealing with them, I know they are a top notch company. If they carry it, then it's a good charger.
ezhitz
11-06-2013, 04:37 PM
I have the ICharger 306B using two server power supplies at 24v I can parallel charge six 4S packs at 30 amps with no problems.
LiPo Power
11-07-2013, 12:21 AM
YES
Power Lab 8 ver.2 and p board.... Very happy with it.... Super power!!!!
http://www.revolectrix.com/pl8_description_tab.htm
http://www.revolectrix.com/MPA_XH.htm
plpflyboy
11-07-2013, 11:02 AM
Thanks for your help guys. Now just to just get the rest of the cash together. Has anyone here modded their own power supplies or easier to just buy them modded?
LiPo Power
11-07-2013, 11:24 AM
Well, it is easier to just get one ready IMO..
I can help, have some ready to go but if you feel like setting yourself up for challenge I am sure you can make one....
http://forums.offshoreelectrics.com/showthread.php?34934-POWER-SUPPLY-47-AMP-by-HP&highlight=
plpflyboy
11-07-2013, 08:11 PM
sweet I might contact you for one sometime. You have a price list?
LiPo Power
11-07-2013, 09:39 PM
I do but to make sure you get the right one I would need to
know what chargers you are going to use.
My simple but powerful 12 volt 575 watts and 47 amp units
are around $55-60 shipped depending of how fast you like to
get it and your location.
Anyways, let me know when you ready. Ill be more
than happy to help...
QUOTE=plpflyboy;536333]sweet I might contact you for one sometime. You have a price list?[/QUOTE]
flraptor07
11-07-2013, 10:05 PM
I'm using a Hi-Tech X4 AC 4 port, It's a 4 bank charger that you can run wall plug or with a power source. It works great for me, I charge my 10s packs on it no problem! http://hitecrcd.com/products/chargers/acdc-chargers/x4-ac-plus-4-port-acdc-multi-charger/product
plpflyboy
11-09-2013, 09:05 AM
I have looked at both the x4 and h4 chargers. For me I think my money might be better spent on a icharger setup. I do like ac /dc chargers for convenience. But I have noticed they are limited in power. To get just 2c I need 10amps for just one battery and somehow I keep getting more batteries..Thanks though
From my experience with icharger 208b i can say only good words.I also had an hyperion but isn't like icharger.
You can also buy 2 ichargers 208b in case somthing happens you will have the other to work with.
Ichargers are the most accurate charger you can buy.
If you consider the 308duo then better buy 4010duo.
Also they have very good power supplies.
walko789
11-30-2013, 12:54 PM
Hi plpflyboy- did you make a selection as of yet?
plpflyboy
11-30-2013, 02:17 PM
I am still looking. the Xmas season isn't leaving much in my budget for myself. I think I will be getting one of the ichargers eventually though.
Mad Racer
12-13-2013, 05:55 AM
I was in the same position a few weeks ago with my new 4s packs. I had a quattro charger but only 50w per channel.
So I bought this and love it. It chargers at a good 200W per channel and is a dual charger using one screen to go back in forth.
For Bang for your Buck it's very good. Just food for thought.:bounce:
http://www.hobbyking.com/hobbyking/store/__17753__Turnigy_Mega_200Wx2_Battery_charger_disch arger_400w_V2.html
