View Full Version : servo question?
Timmy
10-12-2013, 09:07 PM
Hey guys, just wondering what size/torque servo should I use for one of these?(660mm) 3700 kv running on 3s106499
10-12-2013, 10:13 PM
Any standard size servo with at least 50 oz/in of torque should work.
Timmy
10-13-2013, 02:39 AM
Cool, I'm looking at hk high torque metal gear waterproof. They're only 7 bucks, bargain!
TheShaughnessy
10-13-2013, 02:52 AM
A lot of my handling issues have been cured by switching to a servo with more torque and better centering. Your boat isn't that big but would use 50 oz as the bare minimum.
Timmy
10-13-2013, 07:57 AM
Rated for 4.5-5kg so should be plenty. By the way, is your avatar a surge crusher? looks cool.:thumbup1:
Wetter
10-13-2013, 12:20 PM
just curious on too much torque for a rudder servo?
being a lot the new standard size water proof ones seemingly are quite strong.
Chilli
10-13-2013, 12:58 PM
No Problem. The more power you have in the servo, the less stress on it. Hopefully the gears will be stronger and it will last longer.
TheShaughnessy
10-13-2013, 01:01 PM
It's a miss geico with a paint job.
I think you can have a servo that is too fast and will cause twitchy handling but I don't think excessive torque would cause any problems.
Wetter
10-13-2013, 02:16 PM
i was thinking so being end points set properly, just gearing up on switching out some servos soon. coating them with Plasti-dip,
well i do not do it too pretty, brushing it on looks fine but takes a couple of coats, and dipping the servo i had to open servo mount some.
probably get the nice Alum. mounts that are adjustable.
thanx.
Chilli
10-13-2013, 02:38 PM
Nothing a little exponential adjustment can't fix... if you radio is so equipped.
madmikepags
10-13-2013, 02:45 PM
Im a freak, as fast and strong as I can get, my P-boats have BL 250oz/in tq and .07 sec travel and my bigger boats all have 300+ can never have enuf speed or Tq you can always dial the speed back on the transmitter!!!
Timmy
10-13-2013, 11:48 PM
I ended up getting the hk high torque metal gear, two ball bearing, waterproof for 7.99. It rated at 12.5 kg for torque. Should be just enough yea?!
Timmy
10-14-2013, 01:05 AM
Thanx for the advice guys!
mongo
10-14-2013, 03:34 AM
I'm running the same exact servo in my Apparition and my buddy runs it in the Genesis and it's holding up very well thus far.
Centering is good, slop is minimal and it's strong and fast enough for me.
Never noticed any issues in fast straight lines nor while cornering.
I'd definitely recommend it, especially considering the price.
