View Full Version : BJ26 Motor on non-stock ESC??
Darin Jordan
07-22-2008, 10:24 AM
I know that alternate ESCs seem to get hot when used on the SV27 motor...
Has there been any issues with running other-than-stock ESCs with the BJ26 Motor?? Barracuda 125s or Hydro 120s, etc?? Do they work fine with this motor or do they get too hot??
Thanks,
obrien
07-22-2008, 12:52 PM
I have run the hydra 120 on my stock bj with no issues as all.
RCprince
07-22-2008, 01:29 PM
I Run My Ob Bj With The Stock Motor And A Barracuda 125
RCprince
07-22-2008, 01:31 PM
dARIN THE bj MOTOR COMPONENTS IS WAY BETTER THAN THE sv THAT ONLY ADVANTAGE I'LL GIVE THE SV IS DRIVE HARDWARE
ReddyWatts
07-22-2008, 02:12 PM
IMO, the BJ & SV motors are 6 pole, so the controller pulse frequency is 3 times as fast as a 2 pole motor at the same RPM. It also has to stay in correct timing with the rotor at a higher freq. Their controllers were specifically designed for 6 pole motors.
Some controllers handle more poles better than others.
RCprince
07-22-2008, 06:21 PM
Himax which seems to be the manufacture of the BJ motor recommends CC esc's and default settings
RCprince
07-25-2008, 01:59 PM
I got 48.2 mph today on my SV running a BJ motor, Cheap 60amp esc, x440 6s 2200 25c
