View Full Version : 1/8 Scale hydroplane turn left set up
icemanxo
10-01-2013, 12:18 PM
Hello,
I was wanting to set up a 1/8 scale hydroplane to turn left and wanted a reliable setup that I can count on so I don't need to break any speed records plus this is not to race in any club. I need help with esc, motor, right hand prop suggestions. I also was going to use 8s setup or any other input would help thanks for looking. :roflol:
10-01-2013, 03:41 PM
To be clear, you want to run counterclockwise ovals, right? What hull do you have? What are your speed and run time goals? What is your budget?
icemanxo
10-01-2013, 08:16 PM
Correct I'm going to run counterclockwise and was going to order rc boat company hull T-6. I wanted a little more run time than speed (45mph to 50mph) and budget is open. Thanks for replying
icemanxo
10-01-2013, 09:28 PM
Scorpion 4035-800 brushless motor I was looking at this motor any thoughts about this
icemanxo
10-01-2013, 09:30 PM
Magnet Poles 8
Motor Wind 6 Turn Delta
Motor Wire 27 - Strand 0.29mm
Motor Kv 800KV RPM / Volt
No-Load Current (IO) 2.5 Amps @ 8.4v
Motor Resistance (RM) 0.010 Ohms
Max Continuous Current 100 Amps
Max Continuous Power 4200 Watts
Weight 435 Grams (15.34 oz)
Scorpion 4035
jwray
10-02-2013, 10:20 AM
Something to think about is finding a turn fin that is cuped on the right side and you may have to reshape the bottoms of the sponsons to get the boat to slide in turns unless the company will mold the hull for counter clockwise running.
icemanxo
10-02-2013, 02:26 PM
Thanks for the details
icemanxo
10-02-2013, 02:28 PM
Any suggestions on lipo setup like c rating and 6s, or 8s etc
JimClark
10-02-2013, 02:47 PM
8 to 10 S and I would think at the very least 35c (quality cells)
icemanxo
10-03-2013, 12:25 AM
Should I use 1 or 2 packs
JimClark
10-03-2013, 01:31 AM
Dont know if a single pack will fit in your boat. My guess is two would work better for weight distribution
Sent from my SGH-T989 using Tapatalk 4
icemanxo
10-03-2013, 12:46 PM
How many mih for total battery capacity
icemanxo
10-03-2013, 12:48 PM
How much total battery mah capacity should I use and any prop suggestions or esc
mojoracer
10-04-2013, 12:22 PM
I have a Scorpion and it pushes my 19 lb PAy N Pak 60 MPH on 10S
icemanxo
10-06-2013, 07:56 PM
How many mah are you running on the battery's thanks
icemanxo
10-06-2013, 07:57 PM
What kind of run time are you getting thanks
mojoracer
10-07-2013, 06:23 AM
2 5000 mha 5S packs in series so 5000 mha of 10S. I only ran a mill lap plus 6 lap heat on a 1/6 mile course. Used about 3200-3500 mha.
Here is a video of the boat running that motor:
http://www.youtube.com/watch?v=rMKamNMFlPE
icemanxo
10-07-2013, 02:34 PM
Thanks for the video what was the c rating on the batteries
madmikepags
10-07-2013, 08:08 PM
get 2 5S 6000mah Dinogy packs, the scorpion motor works great, you will get better run times and lower temps w/ the 65C dinogy batteries, and they're only a few bucks more than the cheaper ones. Yes these hulls are made to run clockwise so the L and R sponsons usually are different.
mojoracer
10-08-2013, 07:19 AM
I had 25C packs and ended up flaming them up. I would recommend going to higher C rating. I am becoming a fan of the Dinogy batteries myself. Take Mr. Pags advice!
