daign
09-22-2013, 06:35 PM
So I have a lot of experience with multicopters, planes and cars. But have never been into boats until I met a bunch of great guys up at the local pond here in LA. I got hooked after driving my 1234 Dumas Chris Craft Barrel Back around a bit, but a bit freaked out when she rolled without any floatation. No damage and she kept the water out somewhat well, but I realized it was time for a real hull to start with.
https://lh5.googleusercontent.com/-rQozx0Z5GbA/UgHBfxicCzI/AAAAAAAAeko/NXhxwgWXChc/s800/DSC03102.JPG
Some Pix of my work:
Cars, crawlers, scalers:
https://plus.google.com/photos/102046385214554961345/albums/5639321381797573281
Multirotors, quads hexas etc.
https://plus.google.com/photos/102046385214554961345/albums/5639321690172251057?authkey=CNH3peTqqKvuGQ
So had my heart set on a Delta Force Mono Deep V after seeing one run at the lake. Amazing on 4s.
I was browsing the classifieds and came across this DF Clone that was labeled a Arowana but clearly isn't. I'd hate to buy a Delta Force Hull and muck it up by drilling all over etc, So why not learn the basics from a clone.
Specs on the boat from the manufacturer 'TOBSD.com.'
Hull Material: high-quality 4-layer Fiber Glass/Epoxy Resin
l 3Kg Strong servo
l Water tight seal
l Product Size(LxWxH):845×240×130mm
l Motor: 540size BL3665 Brushless Water Cooled
l Pre-installed P1.4 X D38 mm metal Propeller
l Boat Show Stand
l Shaft Drive System: 4 mm Flex Cable Drive
l Turn Fins: double Turn Fins, Aluminium Alloy
l Aluminium Rudder with water intake
l ESC: 120A Brushless water Cooled
Note that they dont mention KV. Wonderful! In the manual they state its a 2900kv with a 40mm prop?
https://lh3.googleusercontent.com/-i72_wspvzcM/Uj9xonL9vFI/AAAAAAAAg88/zdr820EAleo/s800/DSC03222.JPG
https://lh4.googleusercontent.com/-cj0YrVgzxbY/Uj9xlk9ewbI/AAAAAAAAg80/OpIm_v9D-yA/s800/DSC03221.JPG
https://lh3.googleusercontent.com/-68cQQYH9Ztc/Uj9xswYoaPI/AAAAAAAAg9M/l-XDPi23ZsI/s800/DSC03224.JPG
So far on my list:
Heres a picture of the broken servo mount on the left, I'd like to replace it with a nice clean CNC one and a Proper servo, but some 3m trim tape and a ziptie will work if needed.
https://lh6.googleusercontent.com/-EqaJvaDfy88/Uj9x57Sn4vI/AAAAAAAAg-A/DblNTLA7BYM/s800/DSC03233.JPG
1. It was brought to my attention that I need to lose the Spektrum car receiver and telemetry asap and run a marine unit because of Car receivers going nuts on people in boats so I plan to do that. Wish i could keep the temp. telemetry and voltage on my Spektrum DXS3s though.
2. Yank the motor enough to check kv in person. It does resemble the BL3665 Turnigy motors and they do have a 2400. It needs to be verified though.
3. Yank the crappy "waterproof'd ESC (with white silicone) and replace it with a Turnigy 180a.
4. Batteries, all my 4s batteries are 40c or less.
5.Verify the prop. what is the proper way to measure a prop?
Is this sized boat limited to 40-45mph as stated by others or do I have room for growth? Such as moving up to 6s and dropping the kv of the motor to keep temps down.... The Motor mount has ZERO adjustment so I'd have to Remove the old one and replace it.
At that point it may be worth moving onto another hull and building my own anyway as I see it. When I'm comfortable of course. For now I just want to make the boat my own, yank some of the Delta Force decals that do not fit the hull, add my own decals (I have a decal printer) and do my own livery for her.
Thanks for the help all, I look forward to learning more about boats and the 'wet' side of the hobby. The last time I got wet RC'ing I lost a $1400 Hexacopter. I swam like a merman trying to get that thing before it went down! ;)
Cheers,
D
l 3Kg Strong servo
l Water tight seal
l Boat Show Stand
So far on my list:
Cheers,
D
