Margeibel
09-01-2013, 02:24 PM
Running a stock Revolt 30 with a detounged sharpened and balanced stock prop.
ESC Temp low 100s
Motor temp low 90s
Grimm racer 4200mah 14.8v 30c Lipo temp 124-135 after a 10min run.http://forums.offshoreelectrics.com/images/smilies/flammes-09.gif
I removed the y connector to a single deans connector since I'm just one battery.
Esc is running around 110 now
Motor still in the low 90s
Battery in the high 120s ( after 5min only at middle 90) that is a7 to 9 min run.
Also have a GForce elite 4000mah 30c 14.8v. Temp runs in the 1teens 7 to 9 min run.
The question is, is the temp for the batteries to high? I do not want set the boat on fire it is my first and only so far.
ESC Temp low 100s
Motor temp low 90s
