View Full Version : Got my stock Impulse V2 up to 115 KPH / 72 MPH
spanky17
08-29-2013, 01:06 AM
Mind you it was in the back seat of my truck heading on down the highway returning home from the hobby store :doh: . When I bought the boat I also purchased 2 Gens Ace 5000 Mah 40c 3 cell lipos for it . After reading all about the 6 cell issues in these forums I decided to remove the 1800 kv motors and order in the 1500kv motors from Proboat. I will try the stock ESC but change out the connectors to larger ones. can I use 5.5 bullets with the small motor wire that comes with the 1500kv motor. I am not sure about the prop though, can I use the stock prop or can I go one size larger with this set up. I also have the Black Jack 29 and will be changing the motor in that as well. I am going to make a recovery boat over the winter and possibly an air boat as well and will use the stock 1800kv motors in those with a 4 cell set up, I have a few NiMH 3000 Mah 7 cell batteries that I would like to use if it is possible with the 1800kv. To make a long story even longer will I be ok with 6 cell 1500kv motor, stock esc and prop ? Anything else I should do, im all ears/eyes. .......Mike
G-UNIT
08-29-2013, 08:12 AM
1500KV With 6s is ok but The esc won't handle that voltage, go with t180a esc and you should be fine.
try running a m445 or m545 and you should see some good speeds.
spanky17
08-31-2013, 12:02 PM
Thanks for the prop info G-UNIT im a little bit lost when it comes to prop matters, but learning a bit every day.
BHChieftain
09-01-2013, 09:45 AM
Hi Spanky17,
I like your thread title- made me look!
I have a setup/running guide for that boat that has a lot of good info including on props as well, if you PM me your email address I can send it to you (word.doc).
Chief
spanky17
09-01-2013, 11:07 AM
Hi Spanky17,
Chief
PM sent, thank you for the help. I can sure use it.
Hujo R/C
07-19-2014, 08:21 PM
I would like this guide you guys are speaking of also. If anyone could get it to me, you will be most appreciated..
