View Full Version : Swordfish or seaking?
Cinnabun
08-28-2013, 09:56 AM
Looking for a 120a speedo for my revolt. Going to be running 4s with a Leo 3674.
What's the better speedo? They're not much difference in price but I haven't used either one, so I'd like to hear some feedback.
Thanks.
Bduncan
08-28-2013, 10:03 AM
Get a 150 or 180. The revilt runs great on 5s 1p with rigjt prop.
Cinnabun
08-28-2013, 10:06 AM
I'm going to have too much kv(2200) to run 5s, and I also have a ton of 4s bricks that I currently use. Not really looking to switch to 5s.
Bduncan
08-28-2013, 10:14 AM
I have not had great success with seaking. Having said that Steve thinks they are a good value. I like the 200 and 240 castle hydra ice escs. Great for tuning with castle link and you can always use them for a more powerful set up in another boat. Lots of people like the etii as well. Although the hydra ice escs are expensive, if they fail castle is great about.
Replacing them for free. With seaking, good luck.
Cinnabun
08-28-2013, 10:19 AM
I already own a high voltage esc for my genesis. I am only looking for something to run my 3674 Leo assuming the stock revolt esc will probably not like that motor at all.
Between the swordfish and seaking, can you suggest one?
Bduncan
08-28-2013, 10:21 AM
Ask steve
Bduncan
08-28-2013, 10:28 AM
Product ID: hef-HB60120L
Swordfish Pro 120 amp - 6s lipo ESC
In Stock: 4
Click picture for full specs.
Hifei Swordfish Pro 120 amp water cooled esc. This is a high quality ESC designed specifically for racing boat. Programing can be done with your transmitter, optional program card or optional USB adapter or optional LCD Program Box/Handheld Unit.
120 Amps, 2s to 6s LiPo cells.
swordfish: Add a Program Card (+$6.00)
Add a Program Box (+$15.00)
kevinpratt823
08-28-2013, 10:42 AM
Personally I would want more than a 120, just to be safe. That motor can still pull some amps, especially with props bigger than 42mm.
Cinnabun
08-28-2013, 10:46 AM
Hm. I have a t180 laying here, however it's going to have to be shoe horned into the revolt.
MrDriveby
08-28-2013, 10:52 AM
I would go for the Swordfish, having said that i've got some 120a seaking in my twin genesis, and no problems at all. But SF got a bigger range of esc's and in the future if your going bigger you can use the same program box on both boats. But you can't go wrong with either of them.
MrDriveby
08-28-2013, 11:11 AM
Btw for 30 bucks more you'll get the SF220a 2-6, that one is only 8mm longer and 11mm wider than the 120a:-)
Bduncan
08-28-2013, 11:12 AM
Hydra ice 240
Cinnabun
08-28-2013, 11:24 AM
The SF220 is out of stock at the OSE store, thats why I didnt consider it.
Cinnabun
08-28-2013, 11:27 AM
Hydra ice 240
You're talking more than double the price. For sport running, I'd rather take my chances with the SF or SK 120. If the SF220 was in stock I'd go with that.
martin
08-28-2013, 11:33 AM
I know some have got away with the 3674 on a 120a, personally I would go higher 180a - 220a depending on make.
MrDriveby
08-28-2013, 11:52 AM
The Leo 3674 2200kv has a max load of 90A so 120a should do it, but ask when the SF220 will be in stock again;) Bets solution is to go a little bit higher;-)
tlandauer
08-28-2013, 12:09 PM
:iagree: If it is not that much trouble to fit the SK 180 into the Revolt 30, I think it's your best choice given its track record and price point. I will feel a bit short changed if I run this set up with the SK120 although that is one of my favorite ESCs, never had trouble and I consider them throw-away items , now it's more expensive but still a great value.
iridebikes247
08-28-2013, 03:41 PM
Seaking 180
airman66285
08-28-2013, 04:24 PM
I am 5/5 with my Seaking 180 and I have had zero issues with them. Full disclosure, I soldered on 6 extra stiffening capacitors for the sake of insurance. All my boats run 4s and the largest prop I run on any of my boats is an Octura x642. My latest build, an HK Outerlimits SV43, has a Leo 4074 2200kv motor, Octura M440 SBP prop and the Seaking 180 and it just rips. The warmest temp I have ever measured on the motor or ESC was 101 degrees F. It is a very solid, fun, and conservative setup.
Rumdog
08-28-2013, 04:49 PM
wow.
Either swordfish or seaking. Don't get the 120's.
A motors rated amps means next to nothing when choosing an esc.
Cinnabun
08-28-2013, 04:59 PM
I got the hobby king 120a. If it runs warm ill cram my 180a in there
Rumdog
08-28-2013, 05:16 PM
good luck.
Why ask, if you're gonna do whatever you had in mind anyhow?
Cinnabun
08-28-2013, 05:26 PM
I was asking which of the 120's were better.
Thanks for the input from those who answered my question.
MrDriveby
08-28-2013, 05:33 PM
Keep us updated on how it runs:-)
tlandauer
08-28-2013, 05:55 PM
yeah! I want to know too!
