View Full Version : Motor for sv27??
Mich. Maniac
05-09-2007, 06:32 PM
I am going to have to purchase a motor for my sv and was curious if I could get a little more bang for my buck by getting a feigo. I just wondered what size in that line would the stock mount hold if any. winds arent an issue now I just didnt know if I should go all the way with xl series? thanks
avengersteve
05-09-2007, 07:26 PM
if you devcon the wood inside you should be fine.. im not sure what motor would be comparable, but if you need an sv27 stock motor, i have plenty!
SJFE
05-09-2007, 07:30 PM
I hear this is the best and safest upgrade avalable.
SV motor (http://www.offshoreelectrics.com/proddetail.php?prod=dh-gpmg5290)
Mich. Maniac
05-09-2007, 07:35 PM
Yeah I still need that other stuff we spoke about. Ill send ya a pm probly Fri. Payday. Im really building the sv for the little woman so Ill have someone to blow away with my originall build. I need to keep it farely stock and cheap.
Mich. Maniac
05-09-2007, 07:38 PM
Do you guys like the 5 minute or 30 minute devcon?
SJFE
05-09-2007, 07:39 PM
It depends on the use. For structural apps I use the 2ton stuff. for just holding an object down the 5 min is fine.
H&MWill
05-09-2007, 09:43 PM
I have been running a 12L motor using the stock SV ESC on 12 cells for about 6 months with no problem at all and it hauls.
Mich. Maniac
05-09-2007, 09:56 PM
using stock motor mount?
adreher
05-10-2007, 10:08 AM
will that motor work with the stock esc?
adreher
05-10-2007, 10:11 AM
What motor are you running? Do you have a link? thanks
H&MWill
05-10-2007, 11:15 AM
It is a 12 L Feigo from OSE. It works with the stock mount and ESC. I have had great results with this setup.
adreher
05-21-2007, 11:54 AM
The 12L feigo say it will only handle 6-12 cells. I would like to use 14 (since I have sets for that), would it be ok to do that, or would I have to get a XL? Would the stock esc work for the XL?
H&MWill
05-21-2007, 12:22 PM
The stock esc will not handle the XL motor. You should ask Steven at OSE if the L motor will handle 14 cells. I think it will but ask him just to be safe.
