View Full Version : My NEW REVOLT 30.........w/Pictures
JLShip
08-24-2013, 03:34 PM
104234104235104236104237104238
New Revolt......
5/32 Cooling lines, use 3/32 line as a collar(band) to make a tighter fit.
OSE Water Outlet and Bulkhead Fitting
OSE Carbon Fiber Battery Tray, you can change the hold down Velcro straps.
Reinforce Hull extra 1" wide med F/G under tray.
Pulled foam block from Bow, added pool noodle.
Prop X442 spare X445 (worked to be a M445) Both B/S by Chris Hoffmann(Dasboata)
Up-Grade OSE Flex cable 150x 3/16
Dinogy Batteries 4S 5000 65C
Will be running P-Limited Dist. 9 NAMBA (Hopefully I can still drive):Sinking:
Mike Caruso
08-24-2013, 04:36 PM
Love your boat! Good luck racing. One of the problems I just have run into is trimming the boat with a big prop using left rudder.......the water flow STOPS. So I filled the factory water slot pick up, drilled the bottom of the rudder and added an 1/8 x 1/2 hard bass tube. I drilled out the I.D. and ended up with .010" wall thickness. Put a 45 degree on the leading edge it should flow very good no matter what rudder angle.
skiking1739
08-24-2013, 09:42 PM
How in the world did you get the original battery tray out of your Revolt?
Thanks
SkiKing
dirtnsnowrider
08-24-2013, 11:56 PM
[QUOTE=skiking1739;522829]How in the world did you get the original battery tray out of your Revolt?
Thanks
SkiKing[/QUOTE
Mine pulled right out as it was only held in with some white silicone.
JLShip
08-25-2013, 09:25 AM
Skiking
It wasn't really bad, mine came out in pieces, Just take it slow...
Phoebe
08-27-2013, 09:04 AM
Perhaps a dumb question, but why do you remove perfectly good foam only to stuff noodles into the hull? The factory foam is lighter and floats my boat just fine!?
JLShip
08-27-2013, 11:00 AM
It's a personal preference, I've always used pool noodles when I started racing. Easy to remove and you can always get under the deck when needed, weight is not an issue..... When I first started 20 + years ago, used 2 part foam, hard to repair hulls when you can't get inside, went to the NOODLE after the 1ST wreak.
:smile:
skeeler
08-27-2013, 12:46 PM
How did you make the cut-outs in the battery tray for the straps? That looks like a good idea.
JLShip
08-27-2013, 03:05 PM
With a Dremel, Mark how much you want to cut out with marker, you don't need much, clean up with file,Just watch out for the dust, wear a mask if you have one. Placement, raise it about little over 1/8", cut some ply on a 33* 1/4 wide strips enough to go under F/C Battery tray and Hull, Used resin and some cloth on the under side of tray, then used resin on sides, none at each opening, were Velcor Strap go.
skeeler
08-27-2013, 04:43 PM
Thanks. I'll emulate your idea.
