View Full Version : Miss Geico 17 - Replaced servo and it barely moves now?
mattdt83
08-09-2013, 03:40 PM
Hi folks, previous to getting hold of a MG 24, I've got a 17 too. Saltwater knackered it and I've bought new servo and ESC. Plugged in ESC, bound it, but my new servo barely moves, just sorta twitches when I send the steer command.
Any ideas?
Thanks!
mattdt83
08-09-2013, 04:35 PM
I plugged in the old servo and it does exactly the same thing. Extremely tiny movement? Can't find anything about it, could it be the transmitter after binding? I bound it in the house (and then in the garden to check it wasn't interference). Motor goes fine, just steering. Doing my nut in, can't find any info on this problem :S
SweetZ28
08-09-2013, 04:55 PM
try putting like wd40 on the plug contacts and see if that will work.... if not sounds like a bad receiver to me.
put your servo in the throttle channel and test it if it works in that channel it's your receiver.
mattdt83
08-09-2013, 05:31 PM
The ESC doesn't have ports for the channels, they're hard soldered in. Only the servo is detachable. It's weird, the steering wheel does nothing, but the steering tabs will turn the servo. :S
http://www.youtube.com/watch?v=n1PiGSq3eos
mattdt83
08-09-2013, 05:42 PM
Duh. I appear to have fixed it, the steering wheel on the transmitter - I took it off, put it back on, tightened it super tight and its working fine. :D
SweetZ28
08-09-2013, 06:42 PM
I was just going to say if the trim makes it work it's the steering pot you should take it apart and spray like a fader lube or detoxit spray in it to clean and lube it.
mattdt83
08-10-2013, 03:46 AM
Yep all done, thanks pal - most appreciated :)
ray schrauwen
08-10-2013, 05:10 AM
Q: is the motor mount for the MG17 plastic or aluminum??
