smittyj77
08-08-2013, 08:57 PM
Wondering if anyone has a working dual pickup rudder conversion working yet? Only problem is pictures are decieving as ive found out. The hardware is absolutley huge.
I purchased this one from Kintec racing and its huge.
5 Inch Rudder Short Base w/ Dual Water Pickup CNC machined aluminum rudder and mounting bracket with dual water pickups and servo arm. Brass bolt for kickback protection.
5 inch (128mm) from bottom of mounting bracket to rudder tip.
1 1/2 inch (38mm) from transom to leading edge of rudder.
Transom foot print is 1.7" (43.4mm) wide and 1.26" (32mm) high.
Rudder width tapers from 1 1/4 inch to 1.1
Servo arm w/ 2mm swivel. All stainless steel locknuts, bolts and washers included.
103570 103572
I also see that OSE sells this one.
This SpeedMaster rudder assembly is made for large nitro and electric hulls 38" or larger. High quality aluminum, CNC cut to tight tolerances.
The Rudder blade measures 6 1/4" long x 1 1/4" wide.
We offer this with 5 different brackets.
-Bracket with 1 1/8" of setback.
-Bracket with 2" of setback.
-Extended bracket with 4" of setback (pictured).
-XL bracket with 5" setback.
-XXL bracket with 6" of setback.
103571
103570 103572
103571
