View Full Version : Filling a cup in ride pad....?
kevinpratt823
07-21-2013, 11:19 AM
What are people using to fill in and true up a cup in the ride pad? Finishing resin? Bondo? I need to try it on my 45" Sniper to see if I get a little extra out of her.......Thanks for any input.
BHChieftain
07-21-2013, 11:51 AM
Check out the end of this thread-- I used marine epoxy putty and it worked great. I had to combine a hull repair with blueprint, so needed something to bond solid to the fiberglass and patch up the holes. Might be a little expensive for a simple fill, but should be permanent.
http://forums.offshoreelectrics.com/showthread.php?41146-Miss-Geico-dialed-in-strut-modification
Chief
kevinpratt823
07-21-2013, 12:22 PM
Chief
Thanks Chief, looks like good stuff. I'll take a ride to the West Marine nearby and pick some up!
In the meantime, I am curious what others are using as well........?
kwiktsi
07-21-2013, 01:14 PM
I use Autobody Icing and actually just did my Pursuit a few days ago with it as well. It's a 2 part glazing putty that sands super easy.
