View Full Version : "Regular" versus Lifter Prop
Phoebe
07-11-2013, 11:21 AM
Guys,
I accidently ordered an Octura X445 instead of the M445. Is there much of a performance difference between the two styles?
BTW, this is my first post as a newbie. After 30 years of planes, helis, and cars I just bought a Revolt on a whim. I can't believe how addicted I've become in just a week!
Todd Fleury
07-11-2013, 12:00 PM
The M445 is a detounged prop. If you want to really make your revolt perform, take the x445 and sharpen, balance, detounge and backcut the prop.
tlandauer
07-11-2013, 02:39 PM
They ( M445 and X445) are not lifter props. As said above, the M445 is detounged, it unloads the motor a bit more than the X series so it may have an edge as far as top speed is concerned. The latter bites sooner and from a dead stop it gives better accel.
Phoebe
07-11-2013, 03:05 PM
Thanks for the clarification. I understand how the drag caused by the tongue would decrease top end, but, being a newbie I have no frame of reference for how much.
I've searched all over unsuccessfully for detonguing guidelines, how much to remove, etc. Is it purely a hit or miss/experimental procedure or are there some rules of thumb?
07-11-2013, 03:29 PM
http://rcboat.com/prop.htm
Phoebe
07-11-2013, 03:50 PM
Thanks, Fluid. I've seen that and it's pretty vague. Shows the general area but still leaves a lot to be desired. Guess I'll just start reprofiling and test the results...
longballlumber
07-11-2013, 04:17 PM
Stick with what you have and work on getting the boat tuned in well. The difference you will see between the M445 and the X445 is minimal.
Later,
Mike
