jd800
07-07-2013, 06:40 PM
MY stock motor is running fine, my drive cable seems intact, I put on a new stock prop. The problem is when I give it full throttle it seems to want to go but does not hook up well and goes slower than it used to. It appears the prop is cavitating bad, I have tried trim tabs up/down, outdrive up/down, neutral but nothing makes it better or worse, any ideas out there.
