View Full Version : Swordfish 200 amp + esc ?
Andris Golts
06-27-2013, 12:01 AM
Hi all im in the process of setting up the Swordfish 200 amp + esc for my 4s 32'' mono.Should i be using the bec function or disconecting the red wire and use a 6v reciever battery instead to power the reciever? Regards Andris Golts.
HTVboats
06-27-2013, 08:40 AM
I have several SF200's and the BEC's work fine. That said cutting the red wire on a short servo extension wire for the esc and a hard battery makes sure there are no reception or servo glitches. Your call either way.
Mic
Mulisha
06-27-2013, 08:17 PM
Cutting the red wire stops you from doing any programming changes. It's quite easy just to pull the wire out of the harness
Andris Golts
06-27-2013, 11:55 PM
Thanks to both of you for the great information. Regards Andris Golts.
