View Full Version : My take on the Top Speed 3 Conversion/Build
tlandauer
06-20-2013, 02:53 AM
Well, I got the Tunnel Fever awhile aback when I bought a VS1 from mtbenjamin77 and another ML PS-295 from Highflyerbill. The TS3 from Towerhibbies was $89 a pop a few weeks ago, couldn't resist. So here I am. it was intended as a quick build as my work is still going crazy in June, let's see how far I can get before the high summer sets in as I have a shovel nose Miss Timex which needs to be completed. ( Jim Clark's gorgeous build!)
As you see, the transom was COA ( cracked on arrival) as Chilli noted in his build. I performed the first necessary surgery : remove the fuel tank platform and the hump on the middle floor, stuffed with FG cloth rolled into the openings, filled the open space in the inner transom.100880 100881 100882 100883
I ordered G10 FG plate and cut two strips to reinforce the inside, the FG hull is flexible due to the removal of the fuel tank platform.100884
tlandauer
06-20-2013, 03:09 AM
Now the gelcoat has been sanded away and you see how big the crack is, this is cause by the transom doubler inside not extending all the way to the bottom, and flex on the transom would stress the thin FG hull. The dark line is solid epoxy mixed with Great Planes Milled Fiber Glass showing from inside100885. I made a template and cut a G 10 to reinforce from the outside. This will make a bullet proof, hopefully. 100886 100887 100888 and thanks to Properchopper, I learned the bubble trick and this pilot hole drill. 100889
tlandauer
06-20-2013, 03:37 AM
I was told that the ideal layout for the TS3 is for the battery to be placed as far back as possible. I bought Dinogy (4s, 6000mah) from Mark F at the 2013 RCX and these are pretty long batteries at 200mm! I debated whether to put the steering servo in the back and use solid rods or placing the steering mechanism in the front, in the end I opt for the latter. So I need to cut out templates for the radio/servo box. Since I don't to CAD design, this is decidedly mid-20th century approach!:lol: I am using 1/4" basswood for the bottom and the sides are 1/16" birch ply from MidwestProducts. Cross member is 1/4" plywood.
100890 100891 100892, the other "occupants" of my family is not amused at my converted work bench!:laugh:
The partially finished box:100893100894
tlandauer
06-20-2013, 03:54 AM
These are the water lines and I also debated whether to group the three wires from the ESC in one big opening or three separate exits. The latter was easier for me to manage:100895 100896 100897100898 100899
tlandauer
06-20-2013, 04:08 AM
The stock aluminum backing plate is quite thin and knowing how I tend to over do things, I will strip it in no time. I like beefier blind nuts instead. However, because the shape of the transom is narrower on the top, I can't use the blind nuts Great Plane makes for the top, luckily I found smaller ones at a hobby shop. I am using SAE 6-32 bolts and blind nuts instead of the M3 that is featured with the kit. 100900100901100902100903 100904
tlandauer
06-20-2013, 04:24 AM
Think I may be still able to use the stock servo stand, will definitely save me some work: 100905 100906100907
That's it for now, thanks for looking!
I would love to hear opinions regarding how to link the steering arm on the OB. I can't decide whether to use ball link/cup or simply use this: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK076&P=SM
Any suggestions would be appreciated!
Also if I solder the steering cable , anything I need to know? I solder brass w/o any problem, but never soldered steel cable. :noidea:
Gabe_k
06-20-2013, 04:13 PM
looks sweet! ive always wanted to drive an outboard boat
kendt
06-20-2013, 07:44 PM
I just redid the radio box for mine so I could fit a t180 in it.If it was a nose hair wider the cowl wouldn't fit. I put the servo up front and used cables with clevises on the servo end and ball links on the motor end. Soldering cable can be a real pita. Use lots of and lots of flux. I found a soldering iron worked better than a torch. I couldn't get the flame low enough and the solder just dripped off. I actually ran my cables out through the sides of the box about 2in from the servo instead of running them out the back. Im using 6s packs and the cable were a pain inside the box.
Heaving Earth
06-20-2013, 08:56 PM
lookin good tim! do you have any vids of your other tunnels?
capnswanny
06-20-2013, 11:03 PM
Nice Work!
If I were to do-over I too would move the servo forward.
I found the recommended CG of 7.5 to 8.5 worked for me. Weight too far fwd and it hooked and dove.
With my light REK leg I ended up with my esc under my servo aft, the battery butting against the ESC aft, and I cut off fwd end of the box!
To get the COG where you want it you may end up with the ESC on top of the battery to get the weight aft.
jim82
06-20-2013, 11:44 PM
Looking good Tim..:thumbup: With the steering cable on my VS-1 I used Loctite 638.. On the ball link or just plain clevis you can use either but I would use the ball link you can make more adjustments with less bind..
tlandauer
06-21-2013, 01:10 AM
Thanks, I love how they ride on the water and seeing the motor out side is cool too. The outboard really gives me a feeling of machinary, lol...
tlandauer
06-21-2013, 01:22 AM
:buttrock: 6s and t180ESC! Which tunnel are you running? Must be blazingly fast!
I plan to run my cable outside too, I just haven't decided at where it will enter: Plan A is to enter in the rear where the ESC is, the brass tubes will go in at a slight gentle angle and will put rubber belows on inside, then the cable will go to the servo. Plan B is to enter near where the servo is, but I like this better because there will be nothing inside to bother loading/unloading the battery. This means the brass tube will run longer and therefore heavier, I am also trying to save every gram of weight, so in the end I need to think which will be the most weight saving.
Thanks for the heads-up on soldering!
tlandauer
06-21-2013, 01:28 AM
Thanks, Heving Earth!
I unfortunately don't have any videos of these two, in fact, don't have much video on any of my boats. Why??? Ask Lenny, he will tell you why!! :lol:
Seriously, I go alone and I can't drive and video at the same time , ( Lenny will be more than happy to clarify on that for you). I beached my Mean Machine twice during her maiden and I wasn't even holding a video cam.
Hopefully during the summer i can drag my 12 yr. daughter to shoot some vid!:buttrock:
tlandauer
06-21-2013, 01:33 AM
Nice Work!
Thanks, I did study your picures MANY MANY times and I liked what you did. I also like the shape of your box but mine ended up kind of square. :olleyes:
I am planning to leave enough clearance below the ESC should I find it necessary to move the battery that far back. Thanks for the tip!:thumbup1:
tlandauer
06-21-2013, 01:38 AM
Jim, thanks man, I really dig your VS1, I like that tunnel actually more than the TS3, but wanted to have a FG hull plus the price at Tower Hobbies was ridiculously low. I looked at your photos more closely now and I see what arrangement you have for the steering cable. Yeah, I was thinking the same thing with the 638 Loctite. Thanks for the tip! :banana:
kendt
06-21-2013, 08:06 PM
[QUOTE=tlandauer;509874]:buttrock: 6s and t180ESC! Which tunnel are you running? Must be blazingly fast!
Its a ts3 as well. It took some serious head scratching to get a t180 in it. I hope to be testing it this weekend and if all goes well I may be able to get a vid of it running.
dirtnsnowrider
06-21-2013, 08:25 PM
Nice to see you start the TS3 build. I would be very interested in the overall weight of the boat when everything is installed with batts. I will have to re-weigh mine as I have forgotten. If the weight is not too much higher than my lay up I might go this route with my TS2 I am working on.
marko500
06-21-2013, 08:52 PM
Never mind the vids of it running. I want to see pics of how you fit the T180 esc in there. My son has a 32" Woodstuff and I wanted to put a T180 in it but there was no way I could get it to fit.
tlandauer
06-22-2013, 04:06 AM
This is also my concern: I have a feeling that it's going to be a bit heavy. I got no time to build this weekend, but hopefully next week would make some progress. The length of my battery dictates that I remove the fuel tank platform, so with everything on the hull, it is a lot heavier than your TS3, I am sure.
tlandauer
06-22-2013, 04:08 AM
I like to see vid of your tunnel running and how you managed to fit the t180ESC in it as well. :buttrock:
siberianhusky
06-22-2013, 07:26 AM
Lookin ok for rain until this afternoon, hope to see this thing hit the water today!
LOL bringing 3 boats today, not going to be a spectator/retrieval guy! SHould have known better than to bring one brand new boat to the pond.
If this thing runs like the HotShot 7.5 it will be scary fast!
tlandauer
06-29-2013, 04:01 AM
Any videos yet? :drool: :popcorn2:
tlandauer
06-29-2013, 04:14 AM
So the work goes on: the box is too narrow for the cable to enter from the back, it might be my miscalculation, but I had to improvise to circumvent this issue:101416 101418 101419101420 101421
tlandauer
06-29-2013, 04:27 AM
101422, I used CA on the tabs as it will be fast and clean.101423 101424, checking for cable clearance for battery:101425, next I installed blind nuts under the servo tray support. I want to be able to lift the whole thing out for maintenance, not just the servo, too many a time the little wood screw strips the wood!101426
tlandauer
06-29-2013, 05:18 AM
next shows sealing the wood with epoxy. I like how the color and wood grain is bought out :101437 101438.
The open space in the rear portion is not flat, had to use wood blocks to support the box. 101439 Using this unusual inboard CC monster motor :lol: to weigh down the gluing process!101440. CF thin strips on both of the walls to act as lid stop and reinforcement:101441
tlandauer
06-29-2013, 05:30 AM
This shows the funky wood rails that is embedded in the hull from the factory, they are not even straight, oh well, $89 bucks from Tower, made in China, what can one expect?!101442, attaching the box finally: 101443 .
Light weight suspended ESC mount: ( had to come up with a fancy name,:lol:) 101444, 101445, it is high enough for the battery to slide under should the COG dictates that position.
101446.
tlandauer
06-29-2013, 05:42 AM
Internal layout. The lateral beam of the ESC supports the cable tubes as well as the wall of the box! 101447 101448 101449 101450101451
tlandauer
06-29-2013, 05:56 AM
About 95% done:101452 101453 101454 101455101456
One thing was not expected: this particular UL-1 motor has its wire exit at either 1-2 o'clock or 7-8 o'clock, depending how you rotate the motor in its mount, I could not get the wire on the other side because at that position the wires would be bend in such a way that they will have unequal length thus precludes the possibility to mate with the ESC wires, this is the best I can do, I have to look into my bins to see my other UL-1 motors' wire exit---must say I have a few of them and they all exit at the "correct point"
Thanks for looking, sorry about the long windedness!
Cheers!
kendt
06-29-2013, 08:41 AM
Any videos yet? :drool: :popcorn2: The last time I had it out I had a couple issues and didn't get any real good runs. Those dam plugs on the back of the transom leak like crazy on mine. I have since corrected the issues and swapped out the motor for a dr mad thrust 3674.
Im hoping to have it out in the next cple days.
Great job on your build. I like how your cables mount. May have to steal that idea for my hotshot 45.
jim82
06-29-2013, 09:39 AM
I don't think you could have asked yourself for a better job looks great!
tlandauer
06-30-2013, 02:26 PM
Thanks, I am happy with the cable tubes, was going to run the tubes outside and enter near the servo, that way the cables are not inside but as I said, wanted to save weight.
Can't wait to see your Hotshot 45 build, is it relatively straight forward to build? I want to try my hands on a wooden hull, lol...
tlandauer
06-30-2013, 02:27 PM
Thank you for your kind words!
tlandauer
06-30-2013, 02:42 PM
I finished the lids of the box, the front is a Lexan cover , I used E6000 Adhesive---Lexan doesn't adhere properly with CA nor Epoxy. I found that out awhile back, and thanks to Fluid, E 6000 does the job!
101486 101487 101488 101489 101490
I need to mention that I owe many of the ideas to members who have done this before, so a thanks to everyone!
kendt
06-30-2013, 03:42 PM
That turned out really nice. congrats!! I love mine and I've barely driven it.
I actually have two hotshot 45's . I have have the really early fiberglass version And a wooden sprint version. The FG one had a fire And is still waiting a new paint job. The wooden one I picked up locally and had the worst paint job I've ever seen. Its stripped and Im just fixing up a few things. Radio box is pretty much done. And then a quick paint job. It will have a leopard 4082 on it.
Savage Skidoo
10-23-2013, 08:48 PM
Thanks for the tips nice work , I just got a TS2 from Rookie on this site that i would like to convert I've always loved the way they handle . 106843106844 its has the same crack as yours did , is this there weak point
marko500
10-23-2013, 10:34 PM
Here's a good thread on a TS2 conversion.
http://forums.offshoreelectrics.com/showthread.php?1260-Darin-s-Top-Speed-2-FE-Conversion.../page4&highlight=tunnel
