View Full Version : Timing? Stock UL-1
704Authentic
06-19-2013, 09:40 PM
Stock UL-1 w/Seaking 180. What timing number for Best speed? Y or D?
I'm sure it's already on here somewhere - couldn't find it.
Thanks,
Heaving Earth
06-19-2013, 09:54 PM
11.25
siberianhusky
06-19-2013, 09:57 PM
Stock esc is set to 10 degrees, I've assumed that to mean it's a Y wind and use a middle range timing, I run a Swordfish so I don't have that many timing options, low, medium or high.
06-19-2013, 10:28 PM
A few more opinions.
http://forums.offshoreelectrics.com/showthread.php?41530-P-Spec-Hydra-120-Timing&highlight=timing
http://forums.offshoreelectrics.com/showthread.php?33389-Motor-Timing-UL1-amp-Turnigy-120ESC&highlight=timing
http://forums.offshoreelectrics.com/showthread.php?31284-Timing-for-UL-1&highlight=timing
http://forums.offshoreelectrics.com/showthread.php?32249-UL-1-motor-timing-question&highlight=timing
http://forums.offshoreelectrics.com/showthread.php?24749-UL-1-Motor-hydra-120-ESC-Timing&highlight=timing
http://forums.offshoreelectrics.com/showthread.php?22539-UL1-ESC-What-is-the-Timing&highlight=timinghttp://forums.offshoreelectrics.com/showthread.php?12954-spec-rigger-timing-%28UL-1%29&highlight=timing
J.W. Pepper
06-27-2013, 12:08 PM
Stock esc is set to 10 degrees, I've assumed that to mean it's a Y wind and use a middle range timing... answer is yes to all three.
Heaving Earth has the right value, that's where I run my PB 1800Kv in IM-31(v1) - using SK-90A ESC. Got the info here... http://forums.offshoreelectrics.com/showthread.php?34832-proboat-1800kv
Hope that helps,
