View Full Version : SV Prop
sacky07
07-08-2008, 03:26 PM
Hello gang, I'm new here. I am an expierenced rc guy except for boats, brushless and lipos!! haha...Anyway I just bought my first rc boat a SV27. Im going to run her bone stock for now as I learn the ropes of boating and this whole brushless/lipo deal. My question is what prop upgrade does a newbie like me want to get. Should it be balanced? berillium or anther matl.? Any help would be great. Thanks
SweetAccord
07-08-2008, 08:00 PM
For 20"-27" hull use: 3 cell LiPo or 8 cell NiMh, KV motor of 3500-2500kv with prop of 35mm – 46mm Diameter.
For sporting the carbon fiber are good and cheap-good place to find out what prop. will give you what you are looking for in your setup/run time. Once you find the sweet spot get that prop already balanced and sharpened from OSE.
They don't HAVE to be balanced but SHOULD be for may reasons. If you must have a "modified" prop, Beryllium is the way to go yes! Since you are new it may be more to balance and sharpen yourself for now unless you are willing to learn and try. Ideally, Octura X440, X440/3, X645, X646 X646/3 are all good props to run/start with. Stay with the X series to start off. Others here will suggest other types of props.
Peace~
62 bugzilla
07-08-2008, 08:16 PM
The cf 45 from ose is a good bang for the buck prop and alot better than the stock one. On this site has a good search program and you will find all you need to know there in the sv section. The sv is a r rotation and a 3/16 shaft.
SweetAccord
07-08-2008, 08:19 PM
If you want a finished prop:
http://forums.offshoreelectrics.com/showthread.php?t=3223&highlight=props
motoxbob11
07-08-2008, 08:42 PM
The SV should run two 2s lipo packs in series as that is how the stock speed control is wired. I agree that the cf45 is a good cheap choice I use it a lot and I also use a Grimracer 42x55 sharpened and balanced.
ghostofpf1
07-08-2008, 09:33 PM
I use about the same set up in mine with pretty good results.I run 4s 4300 lipos and with the 42 prop it gets about 40mph.I just tried the Octura x445 this last weekend but forgot my cheapy radar gun but it was significantly faster although the motor was pretty hot afterwards.
Ghost
ice329
07-08-2008, 11:20 PM
CF45 or X642
Test0055
07-09-2008, 05:46 AM
Whether you run 12s Nimh or 4s LiPo batteries the K45 prop works good and is a direct bolt on to the SV27 with no balancing or sharpening required.
Me and a friend drive SV27 boats with Graupner K45 (commonly called CF45 here on the forum) props and I find them cheap, fast, bolt on ready and easily available from my LHS and Offshoreelectrics web shop.
.. We ding a lot of them up from collisions and flip overs when racing, so the low price is definately good for a beginner with bad cornering discipline :)
I suggest you get a few of these to run in the beginning and if (when) you feel like spending some more $ and get some bling you get one of them those metal jobs. :)
(Note: I have no experience with metal props, but I feel I get good performance with the K45 and at a price 1/4 of a GM berylium prop, I like them even more.)
This is what I'm talking about:
Link (http://www.offshoreelectrics.com/products.php?cat=58)
Product ID: grp-2317.45
Graupner K Series 45mm
Diameter 45mm(1.77"), Pitch 1.45x45=63mm or 2.48"
Shaft is 3/16"
sacky07
07-09-2008, 09:18 AM
Gee Whiz......THanks for all the responses....Just ordered a couple k45 props. What do I need to seal around the stuffing tube and areas like that that might leak????
ice329
07-09-2008, 10:57 AM
There are full threads on here someplace. I did one or two online with pictures. You should pull everything apart and use a little 100% silicone to reinstall it, that make a good seal and acts so the nuts bolts etc dont come out. I also use it around the tube, but use zpoxy on the inside after you set the tube in a correct alligned position. that sould seal the boat hardwere, then do something with the antenna, and change the motor cooling jacket and your boat will be solid. I still have yet to tighten anything on my original 2 boats, both are water tight from the day I did the job to them.
Fixin to run my white one today with a new prop...heheh got some lipos straped in for this test. Its a 3 bladed secret prop...heheh shhhhh
ice329
07-09-2008, 11:30 AM
First test of the secret prop.... maybe it needs to stay a secret cause it stinks so far. With the 5350 lipos set a inch forward the boat cavitates and just is sucking air the whole time. The boat is really set up for a M445 or X642. I will make a tiny adjustment and strap in a set of my IB3600 packs in the stock position in the boat and see how that makes a differnce.
http://s110.photobucket.com/albums/n103/ice0329/?action=view¤t=MVI_1906.flv
ghostofpf1
07-09-2008, 11:35 AM
I've found that with the lighter lipos I have to move the packs forward quite a bit to get the CG correct...like 3 inches or more from the stock battery tray location.
HTH
Ghost
ice329
07-09-2008, 12:14 PM
Well this concludes my little test of this prop on the SV. Its safe to say I dont like it at all, thinkin the prop diamiter is to little. I will try it out on my tunnel and if no good... I will have a balanced 1740/3 up on swap.
http://s110.photobucket.com/albums/n103/ice0329/?action=view¤t=MVI_1909.flv
sacky07
07-09-2008, 01:34 PM
What type of silicone do folks use on these fe boats? where can I get it?
Rex R
07-09-2008, 02:59 PM
I get mine at the local hardware store-adhesives/caulk (I use aquarium sealer/cement ;))
sacky07
07-09-2008, 03:04 PM
donka rex
ice329
07-09-2008, 03:13 PM
Walmart 100% pure silicone in the color is clear. I see it all over but you need 100% pure silicone. I am sure others work but this I know works
sacky07
07-09-2008, 03:18 PM
anyone have pics of how to grease the stuffing tube? What type of grease do I use?
SweetAccord
07-09-2008, 05:00 PM
Speed Grease works well >http://www.offshoreelectrics.com/products.php?cat=77
As for how to grease? Remove the wire drive and apply a light coat of grease and slide it all back in, nothing complicated really.
http://manuals.hobbico.com/aqu/aqub17-manual.pdf <Page 6 Motor and Drive System Maintenance
Page 5 even already has a good prop suggestion to use. Octura X440, X440/2, X640, M440, ABC 40x53, 40x52/3, Prather 215, 220.
Peace~
Test0055
07-09-2008, 05:08 PM
Yes it's in there.
Basically you undo the coupling on the motor output shaft with a 12 and 10 spanner and then yank @ the prop...The whole cable will slide out.
Clean the flexshaft with wd40 or similair and smear some grease on it, then sllide back in, re-do the coupling with the 12 & 10 spanner and you're good to go.
ps. Keep a 3-4mm gap between the drivedog and strut, the flexishaft need this clearance to have room to contract at high speed.
Rex R
07-09-2008, 07:22 PM
I like to start lubing about 1/2" back( to not grease that bit of shaft that goes into the coupler).
bathtub caulk would prolly work...might be a tad messy tho.
rex
ice329
07-09-2008, 07:41 PM
I like the grim racer grease. It sort of gets better with age. I dont clean the shaft with wd. I like it to cake in the knooks and crannys.. Maybe its just me but I just give it a quick wipe and a little rubbed into the shaft and thats it. With a new boat you need to put more for a while till it builds up.
I will try another prop this week, I have to balance it and 3 bladers are a PIA. I wont ever do it again. I will just buy on from a prop guy or OSE.
SweetAccord
07-09-2008, 07:43 PM
I've been balancing an Octura X440/3 for days now. Yeah PIA! Almost perfectly balanced.
gumby
07-10-2008, 10:49 AM
Hey guys, i am new to r/c boating but i was wondering does the X642 need to be balanced?
mike
egneg
07-10-2008, 04:34 PM
mike
Yes - and sharpened also.
gumby
07-10-2008, 05:52 PM
thanks, how can i get it sharpened and balanced?
mike
Diegoboy
07-10-2008, 06:18 PM
Buy one already sharpened and balanced from OSE (http://www.offshoreelectrics.com/proddetail.php?prod=octsb-x642)
or get the unsharpened and balanced one (http://www.offshoreelectrics.com/products.php?cat=87)and have Egneg sharpen & balance it for you!
gumby
07-10-2008, 10:28 PM
k thanks diego i didn't see those props, ill just buy that.
mike
SweetAccord
07-12-2008, 05:13 PM
Well since we are on the topic, this is coming out:
http://www.aquacraftmodels.com/accessories/aqub9575-lg.jpg
http://video1.hobbico.com/gallery/aqu/aqub9575-deluxe.mpg
I prefer the magnetic Top Flight though.
Peace~
planezero
07-15-2008, 12:21 PM
I balanced my first prop last week, Octura X440/3.
How sharp does it need to be ?
On the aquacraft-models page, Mike says to get it "Razor" sharp.
Im having difficulty getting it any sharper than lets say the standard CF prop that came with the boat.
Whats the benefit of making it sharper, higher RPM ?
Thanks 4 any comments,
Berry
ChaKane
07-15-2008, 03:48 PM
The sharper the prop the easier it cuts through the water. Therefore meaning less torque and strain on the motor and higher RPM's.
SweetAccord
07-15-2008, 03:56 PM
Right, sharper the better, but it does not have to be THAT sharp. Try a hand file and run the file on the edge, then run the file on the back of the same edge and you will make an edge really easy if that makes. I can get them to be sharp as a razor. If that makes sense.
SweetAccord
07-16-2008, 05:30 PM
http://youtube.com/watch?v=hIg7-0qWekc&feature=related
http://youtube.com/watch?v=nzKwQfZnFLM&feature=related
http://youtube.com/watch?v=CFpQcxT0nIg&feature=related
ReddyWatts
07-16-2008, 06:07 PM
That is a great instructional video for "prop sharpening and balancing". Be sure and watch all 3 segments.
