larryrose11
06-14-2013, 09:25 AM
Hello all,
Im building my first Cheetah. It will have a Neu 1520 (1577 KV) motor, T180, running on 6S. Im blue printing the hull, to flatten out the last step to help it not run wet. I plan on running a dual cooling setup.
Im not racing, but I would like to go 60+ MPH.
Because I cant just use some carbon props without them breaking, What is a good choice to start?
Is a CNC 5014 (looks like a X450) a good place to start, or is that too big?
Other member have had good results with 50 mm prop:
with my Neu 1527/1Y 1250Kv I can get well into the 60's for 4 minute offshore runs on 50-52mm props can go even bigger or pitch up the prop for more speed.
Can I just put on larger and larger props till temps become a problem? What is the upper limit on prop size for this hull?
