View Full Version : Sealing without Tape: Whose acheived this?
metoo
06-11-2013, 10:11 AM
I can see using tape everytime I wanna get close the hatch be coming a major pain. Has anyone come up with a better solution for this boat than tape? I have some ideas, but if someone has a proven alternative method, I'd like to see it.
Here is one idea involving foam rubber around the inside of the hatch, extending just a bit below the hatch. The foam is tapered on the ID. A wooden frame is glued to the hull matching the ID of the hulls opening. The frame has a chamfered outer edge. The frame is spray/brush sealed and sanded smooth. I haven't put much thought into the fastening aspect yet.
http://i286.photobucket.com/albums/ll107/redrex3/Public/a2bb4014-3a19-45f7-ba76-5bddc6395a0b_zps86deb5cd.jpg
egneg
06-11-2013, 12:44 PM
I used foam tape in a similar manner on a Campbell vintage hydro. It took 8 screws to keep the hatch tight. Much easier to tape than to remove and install all those screws.
rscheffer
06-11-2013, 01:27 PM
Due to the lack of stifnes, large deck openings and the large forces during an impackt with crashes ist nearly im possible to get a water tight fit without tape .
Same reason why only tape is not the safest way to scure large hatches , in a hard impact the tape can easely be blown away/lose
There for i always secure the hatch with bolds in the corners and tape to make it water tight.
The issue with tape always comes up ones in a while , but it still by far the best insurance for you electical equipment.
06-11-2013, 02:27 PM
If the OP searched he'd find a lot of discussion on this topic. The short answer is that for 90% of FE boaters, tape is the way to go if you want the best chances of dry electronics. Drying out and/or buying new electronics is a lot harder than putting on a few strips of tape...
http://forums.offshoreelectrics.com/showthread.php?38968-Hatch-tape&highlight=tape
http://forums.offshoreelectrics.com/showthread.php?10334-Tape-the-Hatch&highlight=tape
http://forums.offshoreelectrics.com/showthread.php?37677-Seriously-why-do-we-have-to-use-TAPE&highlight=tape
http://forums.offshoreelectrics.com/showthread.php?31113-tape&highlight=tape
metoo
06-11-2013, 02:42 PM
The OP looked at every post in THIS forum. Seeing as how the question is Revolt specific and this was in none of the thread titles, a new thread was warranted. Other boats have different hatch geometries, latch, etc., and sealing methods followed by tape as a seal. The Revolt has tape only.
06-11-2013, 02:44 PM
Don't worry, I won't be bothering you again with an attemp at helping a newbie.
metoo
That, I didn't think of. Thanks. Good point.
BHChieftain
06-11-2013, 10:52 PM
Ha! I was about to say "Fluid, WHERE ARE YOU"!
Chief
Grimracer
06-17-2013, 12:21 PM
Do ya know why I design these with tape hatches? Give yourself some time in this hobby and you will have your answer to your question.. I TRULY am making your life EASYER! Dont question it.. ENJOY IT!
Grim
dirtnsnowrider
06-17-2013, 03:38 PM
Grim
I thank you for consideration and so does my wallet.
Cooper
06-18-2013, 10:31 PM
I agree, tape is the time tested (almost ) fool proof way to go. I've built a few cats with foam seals but they are bolted down as they were saw cats. Even then when a high speed crash happens the hull, hatch can and will flex and allow a high pressure squirt of water in (in the throws of a flip or tumble). But tape can also peal off in a high speed crash as well. The bolts take some time as tape can come off in a hurry if need be (something cooking). As Grimm said its a tried and true method, I just use electrical tape, cheep and stretches.
tlandauer
06-19-2013, 03:11 AM
:iagree: Tape is actually simple and practical, it may not be an elegant solution from an engineering point of view, but it works!
I also like every day electrical tape, I don't care if the color doesn't match, it you can see that then your boat is REALLY slow. lol... :wink: I shy away from the cheapest Chinese ones but mid point price ones are OK, the good 3M stuff may be again too sticky and tend to lift decal/paint too easily.
I also think these tape do the least amount of damage to paint and decal. Next I use Hockey tape, they are stronger, thicker but can lift decal and paint if you are in a hurry.
martin
06-19-2013, 09:05 AM
I also swear by electrical tape costing a fraction of the various water proof tapes around, if you run a lot then this saves a fortune using electrical tape. I also will not just tape hatches on as ive seen to many hatches come of, I use positive fixings that are easy to undo ie 1 or 2 pins at the front of the hatch & a single vertical bolt that is sealed at the rear & taping all round the hatch.
dirtnsnowrider
06-19-2013, 01:35 PM
I like to use clear packing tape. It leaves no residue when you peel it off and it has not come off even when I have had some bad crashes. I like it mainly because it is a lot thicker than traditional hatch tape, hockey tape and electrical tape. The tape holds up well being underwater as long as it is applied to a dry hull. I also tend to paint my boats and that alone has made my lid fit a lot tighter now where it has a snug fit. Rolls of this tape run about 2.69 and last me quite a while.
Heaving Earth
06-19-2013, 02:11 PM
+1 on that
jschab
08-12-2013, 03:15 PM
The best tape I have used so far is Duck brand Crystal Clear. $1.09 a roll at Menards. Wide, flexible and does not leave a gummy residue.
http://duckbrand.com/products/invisible-tapes/standard-invisible-tape/crystal-clear-tape-gloss-finish
